Page 1 of 5 12345 LastLast
Results 1 to 10 of 45
Thread: Hauppauge WinTV+FM USB radio plugin
    Aug 2006
    Hi !
    Im Blasto from Hungary.
    I'm working on a WintTV radio plugin for RC1. This plugin uses the Axife FM Player program (http://www.axife.com/).
    Opinion ?
    VENDOR - Centrafuse veetid's Avatar
    I actually redid Radio completly in RC2..
    Just like a CFPlugin there is an interface called ICFRadio that you can inherit from...
    Full source code for all supported radios will be included... You will simply have to fill in the code in your inherited interface and build Radio modules for any device you want, but use the same GUI as Centrafuse and still get pause/play/rewind/fastforward functionality, mixer/eq control, etc...
    note: It basically has about 10 or more functions like poweron, powerdown, seekforward, seekback, etc... you fill in your code into these functions and compile, then place the new RadioModule in the radiomodules folder and you do not have to design any GUI controls...
    david
    Mar 2005
    Wiesbaden/Germany
    Quote Originally Posted by veetid View Post
    You
    Have you seen my FMRadioHAL ?
    Have you seen areoanderz RDS decoder (certainly in .NET!) ?
    Variable Bitrate inniss777's Avatar
    Oct 2003
    SOCAL
    Quote Originally Posted by Blasto View Post
    Hi !
    Opinion ?
    What model hauppauge will this work with? The 941?
    Opus case. MB 899 core duo 2.0ghz
    Dual vga out, 400 gb hard drive, Centrefuse front end
    zapco 1000.4 for zapco 6.5 componets
    zapco 1100.1 for 2 13" W6.
    Jun 2006
    did you try it? does it work ?
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    So who's working on a Plugin for the Broadcom/Freecom DVB-t USB tuners?
    We need one badly
    Jun 2006
    Hello,
    I need to get the Hauppauge TV/FM Tuner working with centrafuse.
    It worked once then it stopped.
    I only get the image when I start the software delivered with the Hauppauge.
    Centrafuse does not change channels on it.
    What am I supposed to do to get it work ?
    How is the TV Plugin enabled in Centrafuse?
    Anyone has the TV working properly?
    Constant Bitrate urosbe's Avatar
    Mar 2005
    I had exactly the same problem. First when installed WinTV+FM in RC1, TV worked. But radio didn't. After that I realized I don't have Radiator installed. But another day TV stopped working (blank screen and cannot change channels). Then I installed RC2 and radio started working... but everytime I clicked RADIO, Radiator (external applications) showed up. TV didn't worked since first try in RC1.
    I reinstalled everything and I will try with RC4 again
    Uros
    System: VIA EPIA EN15000,512 MB DDRII,M2-ATX,300GB HDD,XENARC 1020TSV,VoomPC case
    USB: Powermate,WinTV+FM,WLAN 54G,Bluetooth,Haicom GPS mouse SIRFIII
    Software: Windows TinyXP Rev06+MinLogon+EWF+HORM+Centrafuse 1.2
    Honda delSol project
    CarDomain
    Feb 2006
    I've got TV working with the WINTV+FM (881 chipset). But no luck with the radio. I've tried Radiator, but the 8x8wdm / 8x8 plugins for radior seem to work very buggy.
    Is there going to be native plugin for the Hauppage WinTV+FM (881)?
    Sep 2005
    Anyone else using the Jidas USB Power FM Radio?
    It is said to be the same thing as D-Link DSB-R100 but I just can't get it to work with Radiator.
    Ended up with this solution:
    Inegrating Jidas power UDB FM radio in CF
    Does NOT look good.. and is in no way touchscreen friendly
  1. wintv radio not launching when i press radio
    By dnkyntz in forum RR Bug Tracker
    Last Post: 12-23-2005, 02:49 AM
  2. WTB: FM Radio for Roadrunner (Dlink USB?)
    By fromplanetbob in forum Classified Archive
    Last Post: 10-18-2005, 07:37 PM
  3. New USB FM Radio
    By sxt173 in forum General Hardware Discussion
    Last Post: 08-24-2005, 03:36 AM
  4. Hauppauge WinTV Radio PCI model 401?
    By miztahsparklez in forum Input Devices
    Last Post: 02-08-2005, 12:10 AM
  5. WTB: D-Link USB FM radio
    By Stine161 in forum Classified Archive
    Last Post: 11-12-2002, 08:02 AM
