Results 1 to 10 of 12
Thread: Electronic Suspension Control
    Newbie Pighixxx's Avatar
    Dec 2006
    Italy
    Thumbs up Electronic Suspension Control
    Hi all,
    we have developed a CF plugin that control pneumatic suspensions.
    first the screenshots:
    the plugin control a self made interface wich read pressure and control 4 valves that charge and discharge the air in the suspensions.
    Ciao,
    Alberto & Roberto
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    Quote Originally Posted by Pighixxx View Post
    Hi all,
    Ciao,
    Alberto & Roberto
    WOW!
    This is beautiful! How much does the interface cost? Is it USB?
    [edit] I see it's serial... does it work with USB->serial adapters?
    Joachim
    Dec 2006
    Italy
    Quote Originally Posted by JC-S60 View Post
    WOW!
    Joachim
    The interface use a serial port.
    Mar 2005
    Wiesbaden/Germany
    Exclamation
    I had the same idea and plans for the next year !
    How do you get the pressure ? (which sensors)
    Do you get the height of the suspensions ?
    (and I think you have a bug in your plugin - you can't control the stiffness... but
    You will find this VERY interesting:
    www.maxtrac.nl
    and also have a look at the "InPro Dynaride Protronic" Suspension
    Yes the spring could also be replaced....
    Elsewhere
    Does this interface with any existing hardware (like the LevelPro from AirRide)?
    Also, does the control/sensor unit have the ability to interface w/ ride height sensors?
    How about the Wiki?
    Dec 2006
    Italy
    Quote Originally Posted by FMode View Post
    I have used industrial analog pressure sensor (0 to 8 Atm = 0 to 5 V).
    more pressure, more height!
    The AUTO function keep the current pressure. The user can change the pressure value (.5 to 4 Atm) for CONFORT or SPORT program.
    Dec 2006
    Italy
    Quote Originally Posted by DarquePervert View Post
    I think ther'is no problem to interface the plugin with existing different hardware. I need only the specifications! The interface use a PIC wich control pressure and valves; this card working stand alone; The CF plugin send commands to the card and receive the status of errors, valves and pressure.
    Mar 2005
    Wiesbaden/Germany
    ehmmm.... if you want COMFORT or SPORT you will need an adjustable (stiffness) suspension like the Maxtrac or the InPro - these come with metal springs but certainly you can replace them with an Airbag to be able to control the height...
    Then COMFORT or SPORT makes sense
    Thanks for the tip Darque !
    The LevelPro is excatly what I have been looking for !
    But it so expensive 1200$ - does someone know what the level and pressure sensors will cost without the ECU ?
    Do we need an extra Suspension Thread Guys (I think this is also interesting for other Frontends) ?
    What could be done with a Yawrate sensor in combination with such a super suspension (Maxtrac with AirBags) I don't need to tell you ! (?)
    Mar 2005
    Wiesbaden/Germany
    I have used industrial analog pressure sensor (0 to 8 Atm = 0 to 5 V)..
    Are you planning to sell DIY-kits ? (would be great)
    No !
    Doesn't work if you tow a caravan or are heavy loaded...
    Dec 2006
    Italy
    In the photo one air suspensions installation for my motorhome. This air suspension kit don't replace the original.
  1. PC climate control?
    By daPyr0x in forum Hardware Development
    Last Post: 01-29-2006, 11:03 AM
  2. Air ride suspension control?
    By dragvette in forum Newbie
    Last Post: 01-22-2006, 04:15 PM
  3. mercury sable w/ electronic climate control
    By sgibbers17 in forum General Hardware Discussion
    Last Post: 01-03-2006, 10:31 AM
  4. My LPT Relay Control Software
    By wizardPC in forum Software & Software Development
    Last Post: 02-13-2005, 01:10 PM
  5. USB FM/AM tuner with RDS/RBDS
    By Seth in forum General Hardware Discussion
    Last Post: 08-29-2004, 07:02 PM
