mine is still doing this thing with that little menu bar up top. once i make it full screen and then back to regular, the bar is gone.
My Install
Software:
CFiG v1
iGuidance Plugin for CF
CarShell
Working shell for a CarPC
StopWatch
StopWatch plugin remade for centrafuse RC1
Nevermind...i copied the new dll into the folder and it didnt overwrite the old...ya its working now but doesnt load up in the bkgrd like the old one but its better then getting an error message...
Actually it is still showing. I triedthe v1_1 and the menu bar still shows...then dissapears .
Hi, I really like what you've done with the embedding program, thanks! I'm still having this one problem though. I downloaded reshacker and removed the zoom buttons from the map as well as the menu and volume button. The problem is with the volume button. When the volume is muted, an X appears on the map in the position where the volume button used to be. I cant figure out how to remove it though. I like to have the volume muted but that X is soo annoying. Anyone know how to get rid of it? Here is what it looks like:
See the X above NAXOS? Thats what shows up when the volume is muted (and is also what I'm trying to get rid of)
This is a great project and I'm glad to see making progress...
As soon as it's ready for a version 1, let me know and I will put it for download on the Flux website, I can't wait!
Great Plugin!!!
david
toberdorf. I have the same problem with the X, but for me MENU is still the to. Maybe you can't see it because of your color. It's not as noticeable as the X
I also have the menu bar problem, but I just do a maximize and everything evens out. I think it's because I'm running 640x480 for resolution and my screen is scaling it to what should be 800x480 I think
for some reason today i was using UMPC in the car with the plugin and it kept freezing up, especially when I opened any menu. and the weird thing is whenever i would click something on the menu, CF would bounce back to the main menu and exit out of the plugin. anyone else having these issues?
could someone tell me how to install this plugin? i think im doing it wrong.
CF 1.10
I hit settings, + , plugin, i browse to where the extracted plugin is...
I highlight the folder, and press ok. ....
that takes me back to CF settings window...
I look for the item CFIG...
nothing there....
*puzzled*
~0okami.Digital
just make sure the plugin is getting copied to the plugins folder.. Exit out of Centrafuse and see if the plugin is getting copied to the Centrafuse\Plugins folder...
If it is not, please post in the bugs thread and looks for an error.log file...
If it does, just reload Centrafuse... Otherwise just close Centrafuse and copy the folder manually to the Centrafuse\Plugins folder and then open Centrafuse...
If it shows under settings, then it's loading... so this all might be you just not assigning a button action to a button, such as replaceming the NAV button with this plugin... It is done under settings, "button layout"...
david
