Page 12 of 23 FirstFirst ... 2345678910111213141516171819202122 ... LastLast
Results 111 to 120 of 228
Thread: CFiG v1 Centrafuse Plugin for iGuidance integration
  1. #111
    Variable Bitrate 0okami's Avatar
    Feb 2006
    USA
    Quote Originally Posted by veetid View Post
    If it shows under settings, then it's loading... so this all might be you just not assigning a button action to a button, such as replaceming the NAV button with this plugin... It is done under settings, "button layout"...
    david
    yup. it shows. Now what was that again about assigning a button action?
    sounds like the missing link im in search for!
    n/m... i found it. i should read your post completely before jumping into action.
    Thanks!
    ~0okami.Digital
  2. #112
    FLAC alti's Avatar
    NY
    in cf go to settings -> button layout -> choose the button that you want -> choose CFiG
    that should be all....
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
  3. #113
    Feb 2007
    Pleasanton, CA
    Brilliant! I am loving Centrafuse and the iGuidance skin... man I can't wait for it to be in my car haha... I've come to a conclusion that Front-Ends that are actually commercialized or soon-to-be commercialized are a much better eye candy
  4. #114
    Jun 2005
    Phoenix, AZ
    I've been messing around with the skin for CFIG, and took a look at the Nexus skin for it as well. I really like the nexus skin, but I was wondering if it would be possible to modify it so that I can change the track forward/back from the CFIG bar.
    Does anyone know if I can change the actions of the buttons to do with via the xml file in the CFIG skin folder?
  5. #115
    Sep 2006
    Denmark (Devil Island)
    Am I doing something wrong.
    Cause mine wont embedded..
    I can still see the "Main menu" in the back...
  6. #116
    FLAC alti's Avatar
    NY
    Quote Originally Posted by spdyscotty View Post
    you can modify the CFiG skin button actions, but only to interface commands with ig that I have allowed for. (the ones currently availible on my skin)
    so no, you cannot change the tracks from the cfig bar.
    Quote Originally Posted by HypeTaxx View Post
    are you using the newest verison?
    and if so can you give a bit more detail about your hardware and software...
    My Install
    Software:
    CFiG v1
    CarShell
    StopWatch
  7. #117
    Sep 2006
    Hi,
    I was not using the latest version but the one from the first post.
    I am now :-)
    BUT
    Now I do not se the "Main menu" but IGuidance puts it self. in the background , I can bring it up by multitasking, but it still do no embedded.
    My system info:
    MB: VIA EPIA MII 12000
    RAM: 512 MB PC3200 Kingston
    HDD: 120 GB 3,5" WD
    PSU: Standard ATX
    Monitor: my 19" wide LG - It will be a 7" motorised in dash in the car
    Software: Windows XP SP2 Danish (not stripped or anything)
    iGUIDANCE 2,12 Europe
    Centrafuse (the latest fra www.fluxmedia.com)
  8. #118
    Sep 2006
    I was not using the latest, but I am now. (used the one from post nr. 1)
    It still do not embedded, but now the size of the Iguidance window is right, but it loads in the background and do not embedded I can bring it up by multitasking
    My info:
    Windows XP PRO SP2 Danish (full, not stripped or anything)
    iGUIDANCE 2.12 Europe
    Hardware:
    Via MII 12000
    120 GB 3.5" WD
    Standard ATX PSU (for configuring only) M2 ATX when it's going in the car
    SORRY Found the reason myself, it was because iGUIDANCE failed to find my GPS reciever and that caused it not to embedded
  9. #119
    Sep 2006
    I am also having the incorrect window size on cfig until I press the maximize button to maximize then minimize. On my desktop pc with basically the same settings the program opens perfectly....
    Also for anyone that would like to not see the speed / distance to destination bar when in minimized mode but would like them visible in full screen I have attached the config and skin.xml settings.
    In the Skin.xml make change the values to match below.
    <CFIG>
    <X>0</X>
    <Y>84</Y>
    <WIDTH>848</WIDTH>
    <HEIGHT>325</HEIGHT>
    <FULLX>0</FULLX>
    <FULLY>0</FULLY>
    <FULLWIDTH>848</FULLWIDTH>
    <FULLHEIGHT>404</FULLHEIGHT>
    <APPX>0</APPX>
    <APPY>51</APPY>
    <APPWIDTH>848</APPWIDTH>
    <APPHEIGHT>308</APPHEIGHT>
    <FULLAPPX>0</FULLAPPX>
    <FULLAPPY>51</FULLAPPY>
    <FULLAPPWIDTH>848</FULLAPPWIDTH>
    <FULLAPPHEIGHT>355</FULLAPPHEIGHT>
    Change the config.xml to these values
    <APPCONFIG>
    <SKIN>Onyx WS Night</SKIN>
    <APPLANG>English</APPLANG>
    <FULLSCREEN>false</FULLSCREEN>
    <PATH>c:\Program Files\iNav\iGuidance\</PATH>
    <ARGUMENTS>nowarning</ARGUMENTS>
    <FILENAME>iGuidanceUMPC.EXE</FILENAME>
    <XOFFSET>-2</XOFFSET>
    <YOFFSET>-47</YOFFSET>
    <WIDTHOFFSET>4</WIDTHOFFSET>
    <HEIGHTOFFSET>66</HEIGHTOFFSET>
  10. #120
    Aug 2005
    I have iGuidance installed and the plugin installed correctly yet when i bring it up in Centrafuse i see an empty white screen where the map should be.. The buttons also dont do anything other than maker a noise..
  1. Traffic Plugin for Centrafuse?
    By justintime in forum CF Plugins
    Last Post: 09-09-2006, 09:09 PM
  2. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 03:43 PM
  3. Sample C# Code For Centrafuse Plugin
    By buurin in forum CF Plugins
    Last Post: 01-27-2006, 05:10 PM
  4. Embedding FM PLugin into CENTRAFUSE 1.1
    By camsgs3 in forum DragonBTV's CarPC Plugins
    Last Post: 01-16-2005, 10:55 PM
  5. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 05:39 AM
