Great job! Much easier than using SKINBedder like I was. Definitely less setup work.
Now, two feature questions to see if it'd be possible..
1. Can it be setup so you can choose if CFiG will start fullscreen? I could do that when I added iGuidance as an app, so when CF starts it will start CFiG and automatically maximize the plugin?
2. This is as much a question for David as anyone..will it be possible to output the speed reported in iNav out to the VFD? I realize CFiG probably isn't really 'interfacing' with iGuidance, but worth asking anyway..
Hello, done some more testing, nothing to do with IG, sorry about that, next time I'll get my facts straight before posting (noob mistake).
this can be done, will try to get it in soon, but no promises on time
As far as I am aware as far as iG goes this can only be done using a OSR algorythim to read the speed right off the screen and then you could likely pass the value through davids api to cf (I have not looked at this part of the api since i do not use destinator currently, so i am guessing here)
however to be honest i am not looking at investing the time needed to do so, I have been working on other projects. If anyone wants to grow this app, let me know.
no worries, good luck with getting it working
My Install
Software:
CFiG v1
iGuidance Plugin for CF
CarShell
Working shell for a CarPC
StopWatch
StopWatch plugin remade for centrafuse RC1
I upgraded to the newest centrafuse version and now iguidance says gps not found when I launch it through centrafuse. When i launch iguidiance outside of centrafuse it works normally. Any ideas?
My Install
Software:
CFiG v1
CarShell
StopWatch
yah you're right. destinator said "no port" for gps but I guess it was using the one for iguidance. I just set it to com 4 and it worked.
Any word on this idea?
Also, with CF 1.12 with default settings on 800x600, the top and bottom get cut off just a hair on my system. I tried adjusting the y offset and the height adjustments, but no combination seemed to solve the problem. If I get the bottom bar to fit, the top was cut off where the guidance directions would go. Was this covered in earlier posts? I may have missed it.
Thanks!
not without changing the skin
try:
<X>0</X>
<Y>84</Y>
<WIDTH>848</WIDTH>
<HEIGHT>318</HEIGHT>
<FULLX>0</FULLX>
<FULLY>0</FULLY>
<FULLWIDTH>848</FULLWIDTH>
<FULLHEIGHT>480</FULLHEIGHT>
<APPX>0</APPX>
<APPY>51</APPY>
<APPWIDTH>848</APPWIDTH>
<APPHEIGHT>268</APPHEIGHT>
<FULLAPPX>0</FULLAPPX>
<FULLAPPY>51</FULLAPPY>
<FULLAPPWIDTH>848</FULLAPPWIDTH>
<FULLAPPHEIGHT>429</FULLAPPHEIGHT>
i just loaded mine up @ 800 x 600 before making the changes to the skin file above and i did not notice anything
My Install
Software:
CFiG v1
CarShell
StopWatch
The download link http://www.gormanly.com/CFIG/CFiGv1_1.zip isnt working for me and I didnt see it on the fluxmedia site is there anywhere i can get the plug in from thanks.
