+ Reply to Thread
Page 16 of 23 FirstFirst ... 67891011121314151617181920212223 LastLast
Results 151 to 160 of 228
Thread: CFiG v1 Centrafuse Plugin for iGuidance integration
  1. #151
    FLAC Nola111's Avatar
    Jan 2007
    New Orleans, LA
    Quote Originally Posted by Ewout_vB View Post
    I'm using Xport3 and I set the com4 (GPS) to be available on 5 and 6. Destinator is set up for 5 and I started iGuidance outside of CF in windows and set the port to 6. However, any time I start iGuidance inside CF it only wants to use port 1 and well doesn't work because of that. Why won't the plug in version use the saved port that the program has without the plug in?
    I don't know why it doesn't work like that, but if you set it from within the plugin, it will work and retain the setting. I had the same issue.
  2. #152
    May 2007
    how do i get to the setting inside the plug in?
  3. #153
    May 2007
    Fixed
  4. #154
    May 2007
    Just so people know if you use CFiG. Set the port to something less than 10, it can't handle anything above for some odd reason. It will load it externally but not inside CF.
  5. #155
    Mar 2005
    Pomona, CA
    Any chance you can add left and right arrows for us using the UMPC version to switch through the various modes? It is a nice feature, and I hate having to bust out my keyboard to see them.
    Possible?
  6. #156
    FLAC alti's Avatar
    NY
    ya, I have been working on something that should fix that right now it is back burned for a short time, I am going on vacation for a month to Italy and Poland but as soon as I get back i will look into it.
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
  7. #157
    May 2007
    Is there any way to make iGuidance mute the music (pause) the way destinator and mappoint do when integrated in CF?
  8. #158
    FLAC alti's Avatar
    NY
    Not the same way unfortunately as there is no sdk for iguidance that would allow this to be done from my software.
    Other forum members had been working on this issue, i remember someone had increased the volume of the iguidance sound files so that they were much louder, there might have been other solutions as well, i am not sure.
    My Install
    Software:
    CFiG v1
    CarShell
    StopWatch
  9. #159
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Quote Originally Posted by Yellow-Snow View Post
    Does the app that auto switches on turn work with this plugin? Is it built in?
    Any Updates on this previously posed question? Thanks
  10. #160
    Dec 2005
    I haven't tried this plugin yet because I still can't decide between destinator and iGuidance. I was leaning towards iGuidance but now I just read you can't mute it when iGuidance voice speaks.
    Does this plugin at least lower the volume when it's giving you turn directions?
    If not, is there any way at all to mute the voice when giving instructions?
    Can't David help with it?
+ Reply to Thread
  1. Traffic Plugin for Centrafuse?
    By justintime in forum CF Plugins
    Last Post: 09-09-2006, 10:09 PM
  2. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  3. Sample C# Code For Centrafuse Plugin
    By buurin in forum CF Plugins
    Last Post: 01-27-2006, 06:10 PM
  4. Embedding FM PLugin into CENTRAFUSE 1.1
    By camsgs3 in forum DragonBTV's CarPC Plugins
    Last Post: 01-16-2005, 11:55 PM
  5. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
