Page 17 of 23 FirstFirst ... 7891011121314151617181920212223 LastLast
Results 161 to 170 of 228
Thread: CFiG v1 Centrafuse Plugin for iGuidance integration
  1. #161
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by blackrsx View Post
    I haven't tried this plugin yet because I still can't decide between destinator and iGuidance. I was leaning towards iGuidance but now I just read you can't mute it when iGuidance voice speaks.
    Does this plugin at least lower the volume when it's giving you turn directions?
    If not, is there any way at all to mute the voice when giving instructions?
    Can't David help with it?
    nothing I can do... iGuidance gives you no SDK, so you get no event or anything to tell you that the program is about to speak or give a direction...
    there was a workaround at some point I believe, but not sure...
    david
  2. #162
    Dec 2005
    does this work for the new iGuidance v4?
  3. #163
    Dec 2005
    San Jose, Ca
    I have all the maps to Iguidance 3, but I cant get the engine to work for some reason. It doesnt work externally either. When I double click the execution file it does absolutely nothing. Any ideas?
  4. #164
    Newbie macbrando's Avatar
    Jul 2007
    Phoenixville, Pennsylvania
    Hey everyone. I need a little help. I installed the CFiG plugin and am using iGuidance 4. When I run iGuidance, my GPS works. When i then close iGuidance and open CF, then go to CFiG, it shows me the map but doesn't seem to work with my GPS. This only happens when I use iGuidance thru CF. Any ideas? I checked all the settings and they are all the way they should be (COM3, 4800 baud). Thanks!!
    | 06 Mitsubishi Raider Durocross |
    | CarPC Project:________________ |
    | Planning: [*******-------] 50% |
    | Carputer: [********------] 60% |
    | Fabrication: [*----------] 10% |
  5. #165
    FLAC alti's Avatar
    NY
    Quote Originally Posted by macbrando View Post
    I do not have ig4 to test with... does anybody else using cfig have ig4 working with it?
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
  6. #166
    Jul 2004
    Make sure you disable the gps com port with the Navigation module. They conflict with each other.
    Everyone has this problem.
    2003 Black Impala
  7. #167
    Jul 2007
    Quote Originally Posted by Dwaine View Post
    Did that... didn't work.
  8. #168
    Newbie KoolAid77's Avatar
    Jul 2005
    Central Florida
    i had that problem too once. I uninstalled my bluetooth drivers and it worked... haven't tried to put them back on since then.
    Crack-puter.... I can't get away from working on this thing...
  9. #169
    Jul 2007
    I don't have bluetooth... :-\
    I switched front ends temporarily until i can figure out what's wrong.
  10. #170
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    I dont see that many new features in iGuidance v4. The interface and everything looks like v3. Maybe I did something wrong...but after I uninstalled v3 and installed v4, the iGuidance window doesnt integrate with Centrafuse.
    Is it possible to just stick with v3 for now, but use the v4 maps? Can I just copy and paste the "iNav iGuidance" folder from d:/ (the cd) onto my C:/? v3 works just fine for me, but I could use the newer map data.
  1. Traffic Plugin for Centrafuse?
    By justintime in forum CF Plugins
    Last Post: 09-09-2006, 10:09 PM
  2. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  3. Sample C# Code For Centrafuse Plugin
    By buurin in forum CF Plugins
    Last Post: 01-27-2006, 06:10 PM
  4. Embedding FM PLugin into CENTRAFUSE 1.1
    By camsgs3 in forum DragonBTV's CarPC Plugins
    Last Post: 01-16-2005, 11:55 PM
  5. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
