Page 19 of 23 FirstFirst ... 91011121314151617181920212223 LastLast
Results 181 to 190 of 228
Thread: CFiG v1 Centrafuse Plugin for iGuidance integration
  1. #181
    Jul 2006
    you're absolutely correct, your theme file and patch for the buttons and icons is GREAT compared to the original version, theres no doubt about that. however, the smaller boxes at the bottom (showing speed, ETA, etc) and smaller turn icons in the non-umpc version leaves more real estate for the actual map, which i like, and it looks really good when you're just driving around and not really looking at the road names, etc.
    is it possible to implement a button on the main interface or even in the settings that switches between the two exe's? that's all that is needed really, to close one and open the other.
  2. #182
    Raw Wave tj!2k4's Avatar
    Oct 2004
    Alti, would it be possible to add the option to start CFiG in fullscreen/maximized mode?
  3. #183
    Dec 2006
    When I click the destination button embedded in CF, nothing happens....I am using europe 2.1.2 should that cause a problem?
  4. #184
    Variable Bitrate kelmk's Avatar
    Aug 2007
    SF
    I just installed this with IG 3 and it's awesome. The only thing is when I exit out of the IG screen the floating turn menu and gps info is still on top of CF. Any way to fix this?
    K.
  5. #185
    Feb 2007
    Hi, Is it comptatible with iGuidance V4?
    Constant Bitrate jwlionking's Avatar
    Apr 2005
    Saxton, PA - Central/Western PA
    Quote Originally Posted by AzN_Tuan View Post
    Works well for me
    DigitalFX4.0 Skin by JohnWPB
    Road Runner RR's Myspace
    My Ride - Car Domain Page -JWLionKing's MySpace Page
    Project 98% Complete -FREE DOMAIN & WEBSPACE / FILE HOST FOR DEVELOPERS - PM ME
  7. #187
    FLAC WuNgUn's Avatar
    Sep 2007
    I can't get it to work with v4 of iGuidance...it just opens on it's own in it's own window, not embedded into CF...
    WTF
  8. #188
    Dec 2006
    Center of the Universe
    So what is the story on this IG4 and the plugin ? Working or not ?
    I have had the IG3 and the plugin for well almost a year now...and I am afraid to upgrade to IG4 for fear of serious headache afterwards.
    I have not tried yet. Can IG3 and IG4 co-exist ? When I install IG4 i just want it on one machine...no funny licensing issues afterwards I hope. One machine ID, one license and that is gonna be my car pc. But I need some reassurance the process is smooth. How did you upgrade ?Is it just as simple as installing IG4 and not touching the centrafuse plugin ?
  9. #189
    Sep 2002
    New Jersey
    Just FYI I'm using IG4 with the plugin and it's working perfectly fine. The only thing that doesnt seem to work is the "Dest" button for the plugin, so you just have to go to the Menu first to input a destination.
    Now if I could just get iGuidance to get a signal after hibernation I'd be all set Hopefully Xport will resolve the issue, I just put it on yestarday so we'll see.
    1991 Camaro Z28
    2004 Acura TL
  10. #190
    Dec 2006
    That is true...you cannot use the DEST button for some reason.
    In the car I have IG3 and an older version of the plugin and CF1.20
    Now I am trying to have this IG4 installed with the old plugin also in CF1.20 but it does not work. It ony works with the plugin as downloaded freshly from the Flux Media website...NOT my old plugin.
    I am uncertain why that is.
  1. Traffic Plugin for Centrafuse?
    By justintime in forum CF Plugins
    Last Post: 09-09-2006, 09:09 PM
  2. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 03:43 PM
  3. Sample C# Code For Centrafuse Plugin
    By buurin in forum CF Plugins
    Last Post: 01-27-2006, 05:10 PM
  4. Embedding FM PLugin into CENTRAFUSE 1.1
    By camsgs3 in forum DragonBTV's CarPC Plugins
    Last Post: 01-16-2005, 10:55 PM
  5. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 05:39 AM
