Hi,
Here is the french translation for your plugin.
Please just explain the 4 lines with "offset" in order to improve the translation.
Yes, I meant ig.
In Ig in centrafuse, hit menu-exit-yes to confirm.
Now that it's closed there's no way to reopen it without exiting CF
Hi,
Thanks alot!
by offset i mean basicly the distance from a another point, example = The top of the ig window is 45 pixels above the top of the plugin window so the ig window is "offset" (from the plugin window) by -45 pixels.
Thanks again for you translation, I will include it with the download as soon as its done.
My Install
Software:
CFiG v1
iGuidance Plugin for CF
CarShell
Working shell for a CarPC
StopWatch
StopWatch plugin remade for centrafuse RC1
i would like to recommend that anyone that has iguidance should download reshacker and get rid of the two zoom buttons, the menu button, and the volume button.
i would say alti could do it but then that would involve hosting the modded iG.exe file and im sure that would just bring a whole nother host of problems.
for anyone scared of messign up their iguidance file, just make a copy of the .exe file before modding in reshacker.
it really is retardedly easy. i am super computer dumb on the software side of things and i was able to easily get rid of those buttons in reshacker. it is really easy to work with and will clean up this integration program just that much more. make it look COMPLETELY integrated.
awesome work alti, i will be downloading soon.
I just put a new version up that checks for the ig process each time you press the CFiG plugin button and reloads it if it is not found. So if you accidently close IG just press the back arrow out of the plugin and go back in.
I also added the french translation, thanks again coucouillu!
My Install
Software:
CFiG v1
CarShell
StopWatch
I have corrected my file with your explaination of offset.
Thanks for the update.
Im having a problem, I open centrafuse, click on the plugin its comes up with a windows error, then click on it again and it works, the windows error just says send or not send, anybody else have this issue ?
Do you mean the send the error report to microsoft box? is this after hibernation or are the any other factors about your setup that you can think off that might help recreate it? I took my webserver dowe overnight to reformat it and start fresh. It is back up and running now but I need to put my sites back up, the download should be back later today, when it is, make sure you have the newest version
My Install
Software:
CFiG v1
CarShell
StopWatch
webserver is back up![]()
My Install
Software:
CFiG v1
CarShell
StopWatch
