Page 22 of 23 FirstFirst ... 121314151617181920212223 LastLast
Results 211 to 220 of 228
Thread: CFiG v1 Centrafuse Plugin for iGuidance integration
  1. #211
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Ok in regards to the problem of iGuidance 4 not embedding properly...I think there is something wrong with my .exe file. I've tried renaming another .exe program to iguidanceumpc.exe, stuck that in the main iguidance directory, and when I launch the program, it is embedded properly into Centrafuse.
    So could I request someone who has gotten their iG4 working with CF to go into c:/program files/inav/iguidance and send me their iguidanceumpc.exe file for me to test out? Maybe upload it on yousendit.com. Thanks in advance.
  2. #212
    Variable Bitrate Phatsacks's Avatar
    May 2007
    Springfield, Va
    Has anyone gotten this plugin from post #199 working with 2.0?
  3. #213
    FLAC Nola111's Avatar
    Jan 2007
    New Orleans, LA
    No. And I haven't seen the author around in quite some time. David says the plugs will have to be recompiled for 2.0 Unless someone has the source for this one, or tracks down the guy who wrote it, we may be SOL for awhile.
  4. #214
    May 2007
    Springfield, Va
    That's...upsetting
    Thanks for the confirmation.
    Navigation is one of my more commonly used apps. I might have to downgrade now, so I can use IG4 =/
  5. #215
    May 2007
    New Jersey
    also interested in getting IG working with CF2
  6. #216
    Jan 2008
    Southern Calif
    Could you guys not run iG4.0 using the add application?
  7. #217
    Ogold007's Avatar
    May 2006
    Los Angeles
    Has anyone been able to track the author down? I am currently using RoadRunner but am planning to switch to CF RC2, however that will change if I can't use iGuidance. Does anyone have the 2.0 compiled version? Better yet, does anyone have the source code so I could compile it myself and also update it for iG v4?
  8. #218
    Dec 2006
    Center of the Universe
    While I am still using the old 1.20 myself, the issue at stake here - as i understand it - is NOT that the plugin does not work with IG4 or with CF2 but rather the DEST button does not work. Something which I can confirm. However the TOP MENU button as well as the left lower panel MENU button from IG4 itself provide the shortcut to the destination. It really is about convenience.
    If you had to use IG4 by itself, one would have to go that route tio input a destination. Not the end of the world but I agree someone should make it work.
  9. #219
    Ogold007's Avatar
    May 2006
    Los Angeles
    I understand that. I can run iG4 in CF1.2 just fine but like you said, the dest button won't work. The problem is that CF RC2 is written in the .NET 2.0 runtime and there have been many changes to the plugin dll. Therefore, as I understand it, cfig needs to be recompiled in 2.0 with the new dll in order for it to work. Does anyone know if this is not correct? Can you still use iG4 in CF RC2 with cfig?
  10. #220
    FLAC WuNgUn's Avatar
    Sep 2007
    I'm using it...
    Haven't tried the Dest button though...hang on...
    Quote Originally Posted by Ogold007 View Post
  1. Traffic Plugin for Centrafuse?
    By justintime in forum CF Plugins
    Last Post: 09-09-2006, 10:09 PM
  2. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  3. Sample C# Code For Centrafuse Plugin
    By buurin in forum CF Plugins
    Last Post: 01-27-2006, 06:10 PM
  4. Embedding FM PLugin into CENTRAFUSE 1.1
    By camsgs3 in forum DragonBTV's CarPC Plugins
    Last Post: 01-16-2005, 11:55 PM
  5. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
