no, nothing changed in regards to which version you use. Just change the filename in the setup from iGuidance.exe to iGuidanceUMPC.exe
My Install
Software:
CFiG v1
iGuidance Plugin for CF
CarShell
Working shell for a CarPC
StopWatch
StopWatch plugin remade for centrafuse RC1
still working on the issue with the error, it seems it happens only with the newer version and seems to only happen when a gps receiver is hooked up (odd)
It works fine when i dont try to hide the ig window until it is done loading. If i dont figgure it out tomorrow I will put up a version with the old embedding code until i get it figgured out.
My Install
Software:
CFiG v1
CarShell
StopWatch
yeah im having the same issue too, I use IGuidanceUMPC, I removed it too, its weird it crashes but if you go back and click the button it comes up just fine, I dont know kinda of weird
I just put up a new version, it worked on my home machine with the gps receiver connected, but my car is at the dealer tonight so i cannot test in the car till tomorrow. please let me know if the new version fixes the problem. (fingers crossed)
My Install
Software:
CFiG v1
CarShell
StopWatch
is there any way to implement the auto-switch to ig thing that justin came up with seen here...
AutoSwitching to iGuidance when approaching a turn
i really do think its an awesome feature.
Does this also work for the Europe version? (v2.0)
Which versions does it work with?
www.superchargedmiata.net - all about roadster lifestyle
My Install
Software:
CFiG v1
CarShell
StopWatch
not sure, is the Europe version like the us version 2.x? or 3.x? If its like the 3.x us version then i would think it would work, but i do not know for sure. If it is like the 2.x us version, then it will work for embedding, but the menu works differently in that version, I am going to add compatibility for that next and there will be a setting in the setup to choose the version.
My Install
Software:
CFiG v1
CarShell
StopWatch
ok cannot wait!!!![]()
If u need a copy of the EU version for testing purpose, just let me know![]()
