Here's the language file for German. I saved it as unicode- hopefully that will preserve the non-English characters. I am sure there's a way to do that properly in XML but I don't know how.
dont re-install xp because of that..... could be CFiG
are any windows popping up while ig is loading?
anyone else having the same issue?
My Install
Software:
CFiG v1
iGuidance Plugin for CF
CarShell
Working shell for a CarPC
StopWatch
StopWatch plugin remade for centrafuse RC1
are you talking about the warning window? try adding nowarning to the command line arguments in the setup and see if that helps (instead of letting cfig close the warning window)
also what hardware are you running (cpu and ram)
My Install
Software:
CFiG v1
CarShell
StopWatch
My Install
Software:
CFiG v1
CarShell
StopWatch
I have the same problems with nowarning, only the warning window does not flash up at all.
I am running it on an m10000 with 512 ram and bu-353 gps.![]()
anyone have it running successfully on a m1000? I dont have any epia hardware to test on.
My Install
Software:
CFiG v1
CarShell
StopWatch
I want to say, this Cfig thing is pretty sweet, thanks for all your hard work.
I have a problem not mentioned here so far,
first, while the nowarning command line works great, I get another little popup flyout thingy that has 5 buttons on it,
the speaker icon (for volume), the gps info button, the north/heading up button, gps disconnect/reconnect, and the full screen button.
this has its own little title bar, (blank) an X to close it, and it is floating over the menu buttons. is there a way to start iguidance without this stupid thing?
I hate having to close it every time I open ig.
second, I dont know what the score is, but the "MENU" button within CFIG does nothing. I click it. nothing. same for the dest button.
am I doing something wrong?![]()
.______
/ '__|__\____ VW CarPC project
\(o)_____(o)/ Full Spead Ahead!
Props to my Sponsor, Summit Adventure Systems Mobile Climbing Walls
www.summitadventuresystems.com
one more thing,
my ignav window dowsnt look anything like yours.
what modification or iguidance are you using to get that?? I really like that bar accross the bottom of your ignav window with the speed, eta, etc on it.
.______
Could someone write an autoit script that launches iguidance with the nowarning param and see if the plugin still crashes iguidance...could be a work around...
