Page 8 of 23 FirstFirst 123456789101112131415161718 ... LastLast
Results 71 to 80 of 228
Thread: CFiG v1 Centrafuse Plugin for iGuidance integration
  1. #71
    Constant Bitrate AngryMan's Avatar
    Aug 2005
    Lewiston, Maine
    ooh.... why am I the last to find out that Iguidance 3 is out... here I am trying to get CFiG working with 2.1.... no wonder it wont work.
    .______
    / '__|__\____ VW CarPC project
    \(o)_____(o)/ Full Spead Ahead!
    Props to my Sponsor, Summit Adventure Systems Mobile Climbing Walls
    www.summitadventuresystems.com
  2. #72
    FLAC alti's Avatar
    NY
    Quote Originally Posted by m2x0p9x View Post
    Could someone write an autoit script that launches iguidance with the nowarning param and see if the plugin still crashes iguidance...could be a work around...
    what are you tring to work around? is it still not embedding with the new version? So far only one person (marshes) has reported having an issue with it with the new version. Are you having trouble as well?
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
  3. #73
    FLAC alti's Avatar
    NY
    Quote Originally Posted by AngryMan View Post
    I want to say, this Cfig thing is pretty sweet, thanks for all your hard work.
    I have a problem not mentioned here so far,
    first, while the nowarning command line works great, I get another little popup flyout thingy that has 5 buttons on it,
    the speaker icon (for volume), the gps info button, the north/heading up button, gps disconnect/reconnect, and the full screen button.
    this has its own little title bar, (blank) an X to close it, and it is floating over the menu buttons. is there a way to start iguidance without this stupid thing?
    I hate having to close it every time I open ig.
    I am not sure what window you are talking about here, my only guess is that it is one of the ig menus, did you do that modification to ig to try to remove the warning box that makes ig not remember any of the settings when you close it? if that is the case and you had that window open the last time it saved settings it might reopen it every time. It does not sound like it has anything to do with cfig though.
    second, I dont know what the score is, but the "MENU" button within CFIG does nothing. I click it. nothing. same for the dest button.
    am I doing something wrong?
    As you noted in your last post, I have version 3 running, the menu button does not work with version 2 (yet) I have been meaning to add this, but i have to find my old ig 2.0 and re-install it to test. The dest button does not work in version 2.0 either.
    My Install
    Software:
    CFiG v1
    CarShell
    StopWatch
  4. #74
    Aug 2005
    Lewiston, Maine
    Alti, thanks for the response. I was using 2.1. now I have 3.0 and it looks much better. I love the new look and feel.
    I still have tthe extra buttons in iguidance tho, and I hadnt made any mods to it other than the "nowarning" command line. regardless, my work around to hide those buttons was to change the Y offset and height of the app within cfig to:
    Y Offset = -70
    Height Offset = 89
    looks great on my screen now
    .______
  5. #75
    Aug 2005
    Lewiston, Maine
    actually, not sure if this makes any difference, but I am runnign my screen at 800x600. I never did get my screen to run 800x480 with the onboard video.
    *shrug*
    .______
  6. #76
    VENDOR - Centrafuse veetid's Avatar
    This is great work alti!! I can't wait to get this up on the site once you get all the bugs worked out...
    again great work and email me if you have any questions, need any help, or need anything added to the SDK to help you finish the development of this plugin!
    david
  7. #77
    Variable Bitrate m2x0p9x's Avatar
    May 2002
    Modesto, CA
    it embeds fine...i was just wondering if using an autoit script would fix the error with the nowarning param...
  8. #78
    FLAC alti's Avatar
    NY
    I am not aware of an error with the nowarning param.. are you getting one?
    My Install
    Software:
    CFiG v1
    CarShell
    StopWatch
  9. #79
    Sep 2006
    Is it possible to make iguidance 2.1.2 compatible? There are no europe maps for version 3 (
    btw: From which year are the 2.1.2 maps?
  10. #80
    FLAC alti's Avatar
    NY
    Quote Originally Posted by dudeness View Post
    ya, should not be a problem. Going to start working on that now if the app is running stable.
    I am not sure if there was different release dates for the versions for different locations. I think 2.1.3 was released in late 2005, please don't quote me on that.
    My Install
    Software:
    CFiG v1
    CarShell
    StopWatch
  1. Traffic Plugin for Centrafuse?
    By justintime in forum CF Plugins
    Last Post: 09-09-2006, 10:09 PM
  2. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  3. Sample C# Code For Centrafuse Plugin
    By buurin in forum CF Plugins
    Last Post: 01-27-2006, 06:10 PM
  4. Embedding FM PLugin into CENTRAFUSE 1.1
    By camsgs3 in forum DragonBTV's CarPC Plugins
    Last Post: 01-16-2005, 11:55 PM
  5. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
