Page 9 of 23 FirstFirst 12345678910111213141516171819 ... LastLast
Results 81 to 90 of 228
Thread: CFiG v1 Centrafuse Plugin for iGuidance integration
  1. #81
    Sep 2006
    Ok, thanx
  2. #82
    Jul 2006
    i also have the issue with the menu showing up on the first launch....
  3. #83
    FLAC alti's Avatar
    NY
    is it the main ig menu? (the one you get when pressing the cfig menu button?)
    if someone could get a screen shot, that would be great...
    are you also using 2.x like angryman?
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
  4. #84
    Jul 2006
    nope its v3, and yes its the main menu.
  5. #85
    Jul 2006
    Quote Originally Posted by alti View Post
    I am not aware of an error with the nowarning param.. are you getting one?
    the parameter is working fine with me. make sure u don't put a hyphen or anything in front of it, simply 'nowarning'
  6. #86
    FLAC alti's Avatar
    NY
    Quote Originally Posted by hari-bhari View Post
    And if you open ig normally from windows does the main menu pop up then as well?
    My Install
    Software:
    CFiG v1
    CarShell
    StopWatch
  7. #87
    Variable Bitrate m2x0p9x's Avatar
    May 2002
    Modesto, CA
    Im not using the version where is shows the screen flash when it opens...im using the version that took care of that but crashes every other time...anybody have an autoit script just to load iguidance with the no warning param..and then leave the nowarning out of the plugins xml...just wanted to try and see if it still crashes every other time...
  8. #88
    Aug 2005
    Any way to get rid of the buttons generated for the iguidance menus? I rather use the pop-ups and have more screen space for the maps.
    -mike
  9. #89
    FLAC alti's Avatar
    NY
    Quote Originally Posted by Paisan View Post
    -mike
    sure just make your own skin, you could remove all the buttons altogether if you want. You can adjust where ig embeds using the second setup screen to fit your skin.
    My Install
    Software:
    CFiG v1
    CarShell
    StopWatch
  10. #90
    FLAC alti's Avatar
    NY
    Quote Originally Posted by m2x0p9x View Post
    the nowarning param should not be what is causing it crash. It has to do with ig being in a hidden state when CFiG is embedding it and ig trys to find the gps. I cant say for sure what is causing it because i cannot see the ig code, but my best guess is that it has something to do with ig redrawing the map to your current location once the gps returns coords... because the window is hidden it crashes at this point, this is why it worked if the gps was not attached or did not have a signal, the ig window was not redrawn while in a minimized / hiden state. (again my theory)
    the only way to fix it was to run the program visible, hence the jumping around the screen. It should have nothing to do with the nowarning param, running the executiable from a script should not going to have any differnt affect.
    however by all means go ahead and try and let me know if you are successfull. Then i know i can re-explore starting ig in a hidden state.
    My Install
    Software:
    CFiG v1
    CarShell
    StopWatch
  1. Traffic Plugin for Centrafuse?
    By justintime in forum CF Plugins
    Last Post: 09-09-2006, 10:09 PM
  2. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  3. Sample C# Code For Centrafuse Plugin
    By buurin in forum CF Plugins
    Last Post: 01-27-2006, 06:10 PM
  4. Embedding FM PLugin into CENTRAFUSE 1.1
    By camsgs3 in forum DragonBTV's CarPC Plugins
    Last Post: 01-16-2005, 11:55 PM
  5. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
