Page 1 of 23 1234567891011 ... LastLast
Results 1 to 10 of 228
Thread: CFiG v1 Centrafuse Plugin for iGuidance integration
    FLAC WuNgUn's Avatar
    Sep 2007
    Quote Originally Posted by Ogold007 View Post
    But you were able to installed cfig on RC2? When I even tried it, it said that no installation of CF could be found. How were you able to do that?
    I just extracted the plugin in the CF plugin folder...
    Then manually added the CFIG button. Then went into CFIG setup...
    Sep 2007
    Maybe you can share your modified .exe with users here?
    Quote Originally Posted by tibby01 View Post
    i would like to recommend that anyone that has iguidance should download reshacker and get rid of the two zoom buttons, the menu button, and the volume button.
    i would say alti could do it but then that would involve hosting the modded iG.exe file and im sure that would just bring a whole nother host of problems.
    for anyone scared of messign up their iguidance file, just make a copy of the .exe file before modding in reshacker.
    it really is retardedly easy. i am super computer dumb on the software side of things and i was able to easily get rid of those buttons in reshacker. it is really easy to work with and will clean up this integration program just that much more. make it look COMPLETELY integrated.
    awesome work alti, i will be downloading soon.
    FLAC alti's Avatar
    NY
    Download is availible on CF's site on the downloads page
    I finally have everything cleaned up and ready for a official release. Please let me know if you have any issues at all (even the small details), I want to make sure everything works properly.
    What’s new:
    New Embedding Code – Keeps ig minimized (hidden if your taskbar is removed by CF while CF is running (recommend) until completely loaded. Then it is drawn on the screen. I think this looks significantly better then the old method, and should eliminate the ig window jumping around the screen on load.
    Command line arguments accepted – yes, that’s right nowaring (or any other) can be used and it works great.
    Note: As far as I know the nowarning switch does not work with version 2.0NA, if you have this version please just leave the nowarning switch out and CFiG will close the warning box on its own.
    Complete setup! - the screen shots are pretty self-explanatory, the second screen controls the positioning of the embedded ig window.
    Defaults:
    X = 0
    Y = -45 (hides the menu bars)
    Width = 0
    Height = 64 (hides the bottom bar)
    IG process monitoring - If ig is closed accidentally (through the menu or otherwise) simply back out of the plugin by pressing the back arrow and then go back in. IG will be reloaded as long as there are no IG processes currently running.
    Screenshots:
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
    FLAC alti's Avatar
    NY
    Also if anyone translates the language file for any other languages I would like to include them with the download, PM me.
    My Install
    Software:
    CFiG v1
    CarShell
    StopWatch
    VENDOR - Centrafuse veetid's Avatar
    Awesome work!!!
    Can't wait to get this on the site!!
    david
    Aug 2006
    great work I will try this on tomorrow...
    Maximum Bitrate NiSlo's Avatar
    Nov 2006
    Gold Coast, Australia
    What's the advantage of using Iguidance over the destinator that comes with centrafuse?
    I installed my carpc into my pet Kangaroo, mate.
    Aug 2006
    for me was the maps for destinator where not available, maybe I didn't look enough but I just coulnd't find them, I downloaded some by chance of a file sharing but that's it, and I've used Iguidance for quite some time even while using other gui's and it works great, directions are flawless most of the time but I guess you just get used to one program.
    Mar 2006
    Just tried it quickly and wow it works great.
    One thing that bothers me (It's a stupid thing to do, but I still manage to do it on occasion). If you exit the program inside CF the only way to get it back is to close CF and reopen it.
    Any chance on making it check to see if it's already loaded or not when you press the cfig button?
    FLAC alti's Avatar
    NY
    Quote Originally Posted by bland View Post
    The plugin should stay open, do you mean ig?
    Yes that is a good idea, should not be a problem.
    My Install
    Software:
    CFiG v1
    CarShell
    StopWatch
  1. Traffic Plugin for Centrafuse?
    By justintime in forum CF Plugins
    Last Post: 09-09-2006, 10:09 PM
  2. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  3. Sample C# Code For Centrafuse Plugin
    By buurin in forum CF Plugins
    Last Post: 01-27-2006, 06:10 PM
  4. Embedding FM PLugin into CENTRAFUSE 1.1
    By camsgs3 in forum DragonBTV's CarPC Plugins
    Last Post: 01-16-2005, 11:55 PM
  5. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
