Quote:
If I enter a reminder time, the note doesn't show up on the list.
Hmm so if you add reminder the note is not listed?
Quote:
If I don't enter a reminder time, then an entry goes into the list, but nothing shows up in the big box on the main screen.
Which big box on the screen? You must use night skin that is included and shown in first post here.
Quote:
If I enter text next to the time in the NOTEs box, then it won't show up on the list until I exit the list back to the main screen then come back in.
Could you explain more.
The first OSK dialog shows current time and you can enter note next to it or delete it and than enter note. It is just the same as it is in current 1.0 version that show time when you enterd note. (User will be able to remove this time in settings. All the code is there just have to code the settings).
Than if you select to enter reminder you get new OSK dialog that shows hh:mm. You must delete this and enter time for reminder in that form. (for example: If you want reminder at 1:20 AM you enter 01:30).
Quote:
If I double click on a list entry to hear the entry be read, then after the reading it goes back to the main screen. I'm thinking it should stay on the list screen.
OK, this is done.
Quote:
The reminder time entry is clumsy and a bit confusing. You're only looking for a time entry here, right? What about using a smaller version of what David's using to set the time in CF? Basically show a screen with the current time in HH:MM, then up/down arrows under it for the user to scroll the time?
OR! A single screen with the event time, reminder time and notes entry all at once. I think you can do it without it looking too crowded. It would avoid the confusion of having to enter times by hand, and where text can go and where it can't.
David replay to this so... this is simple temporary solution until new version of CF is available.
Quote:
The date format shown on the reminder list isn't tracking with the regional settings. For example, Calendar is using DD.MM.YYYY, but I have MM/DD/YYYY defined in Windows.
Huh sorry, I allready changed this and for me it works.
Quote:
When you pop up your modal dialog for the reminder, it'll pop up behind CF if I'm in an external application when the reminder comes up.
