I can add a parameter to the SDK...
david
Auto-close message box worked out good. Now I call this to send system into STANDBY mode:
How can I disable confirmation prompt ?Code:CF_systemCommand(CF_Actions.STANDBY);
david
Quick question on the same topic: does CF catch system requests to Shutdown/Standby ? In power settings I enabled Standby after 3 minutes of inactivity while running on battery. However, 10-20 minutes later I came back and when turned on the screen I saw that CF was still running and showing confirmation dialog about Standby!
Can you confirm that ?
it should not be doing this... I know it doesn't for shutdown, I will check...
david
