The default size is 848x480 and it scales it to fit whatever resolution you need. You'll need to make sure you take that into consideration so that the logo graphic you chose isn't distorted when it's scaled.
Heya,
I've had alook around and couldn't find an answer, so can someone tell me what size skins should be. Ie. When I'm making a skin, what size should I set my images at? Whether that be a pixel x pixel size or an aspect ratio.
I know I could make it it the resolution I use (640x480), but then it would no good to others using a different res...
I installed my carpc into my pet Kangaroo, mate.
