Well went ahead and edited the 1.2 XML to work with the Aura skin...works just fine...if anyone else is using 1.2 and would like the XML...post or pm..
Trying to get the Aura skin to work with 1.20...when using the Aura skin file everything lines up but any button with text doesnt work also the text does not show and the icons do not refresh when pressed...when using the skin file for onyx everything works but alot of things do not line up correctly...anyone got this working...trying to avoid going threw the xml to edit..
If you don't mind, I'd like to get that xml.
Do you know of any other skins that work nicely with 1.2? I haven't had much luck with skins in 1.2 presumingly because of xml differences between the different versions and custom skins.
should have just done this in the first place..haha...nothing special for the old aura skin...rename skin.txt to skin.xml...mp3car doesnt see xml files...and replace the xml with the one attatched...
awesome! Thanks!
