Page 13 of 17 FirstFirst ... 34567891011121314151617 LastLast
Results 121 to 130 of 161
Thread: Brushed Metal for CF
  1. #121
    Constant Bitrate Meta's Avatar
    Dec 2004
    Indiana
    Quote Originally Posted by jheissjr
    I am having a problem getting CF to use your skin. When I change the skin to be your new skin under CF’s settings window, I get an error window and CF has to be closed. When I try to open CF back up another error window pops up and CF will not open after I close the error window. The only way to fix the problem of CF not opening after I set it to use the new skin is to reinstall CF. Does this have something to do with the .xml file? I tried downloading the new 848 x 480 skin.xml but the link is broke. Any ideas?
    You are right. The link was screwed up. Should work now. Try this: 848x480 skin.xml. You might want to try the "Right-click, Save As" instead of following the link directly.
    I'm not 100% sure, but I have seen error messages pop up when I've screwed up something in the XML file and CF can't find the info it's looking for, or if there is an image file missing that CF expects to be there. It's likely one of the 2.
    After trying the above XML file, if you still get the error message, can you post what it says?
    Also, you don't need to reinstall CF necessarily. You can copy/paste the default /skins/848x480 directory over the "bad" one, overwriting everything, and CF should start up just fine, allowing you to change back to the 'real' default skin, then deleting the bad directory in the /skins folder.
    Hope this helps.
    -Meta
  2. #122
    Dec 2004
    Indiana
    Quote Originally Posted by execute
    Meta, any plans on making a PhoneControl brushed metal skin to match CF's?
    Yeah, that's the next step. I started working on some ideas for "BrushedAluminum" as a "day skin", as, after finally seeing BrushedMetal in the car, the dark screens have a pretty heavy glare/reflection on my Xenarc. But then I figured I had better finish BrushedMetal before starting on something else. I should be able to finish the PHONE pages this week and call it done.
    As for BrushedAluminum, here's a quick peek, again using Feb's images and styles.
    Anyone care for such a beast?
  3. #123
    Nov 2004
    Philippines
    Meta, sweet so after you finish the phone pages, you'll enable the phone button on the lower right?
  4. #124
    Constant Bitrate asci01's Avatar
    Jun 2004
    Florida
    Quote Originally Posted by Meta
    Me like it. Where/when can we have it?
  5. #125
    Dec 2004
    Indiana
    I thought I read previously that the PHONE would only be accessible in future versions from the Main menu. I was reserving that empty button the right for a global Power button. I guess it depends on what David makes available in the next rev.
  6. #126
    Dec 2004
    Indiana
    Quote Originally Posted by asci01
    I'm going to shoot for the end of February.
    The brains of my carputer (a new M10000 in a Morex 3688 case) will hopefully arrive Wednesday. My plan is to finish the BrushedMetal, release BrushedAluminum, then complete my own install in time for Spring. After that,I think I'll retire... at least until next winter. hehe.
    Ya gotta drive the thing, right?
  7. #127
    Feb 2005
    Philadelphia, PA
    Thanks Meta! I put in the new xml and it works great. Do you have plans for putting in buttons for external applications? I want to make a scrolling LED sign for displaying out the back window (yes I know its technically illegal) and have a small program to control its text, maybe even have it voice controlled (say a phrase and it will be displayed on the sign). I also want to put in an HVAC control program, and I also had the idea for a PA system. I looked for a place that already has the option to set up launching external applications like MediaCar does, but I donít see anything like that on CF.
  8. #128
    Raw Wave tj!2k4's Avatar
    Oct 2004
    You bastage!! I wanted to do the same thing but haven't found a reasonably priced display. Let me know if you find something. http://www.mobileled.com/ ?
  9. #129
    Feb 2005
    Philadelphia, PA
    Hey 2j!2k4 I have a Mustang too, its just a 96 coupe though Do you have any pictures of your install. I would love to see them.
    I was going to make my own sign. I did a Google Search and it turned up some helpful information. One good site is http://www.nutsvolts.com/PDF_Files/LEDsign.pdf which is from a magazine I subscribe to.
    I am thinking about controlling the sign with a PIC so I could simply send it the text to be displayed through the RS-232 port and leave it up to the PIC to do all the scanning. This would produce less over head on the computer and as is a more 'professional' design approach in my opinion.
  10. #130
    Jun 2004
    Florida
    Absolutely. Sounds good to me.
  1. Febsperanza Brushed Metal - Frodo Skin?
    By millec in forum Software & Software Development
    Last Post: 12-02-2004, 01:01 PM
  2. New brands for Brushed Metal Skin are up!
    By febsperanza in forum FrodoPlayer
    Last Post: 11-06-2004, 05:52 PM
  3. Replies: 10
    Last Post: 11-01-2004, 08:28 AM
  4. Customized Brushed Metal: Feedback Please!
    By Toups in forum MediaCar
    Last Post: 07-19-2004, 03:41 PM
  5. VB help needed - DVDplayer- Brushed metal
    By Custommx3 in forum MediaCar
    Last Post: 06-11-2004, 02:03 AM
