Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Brushed Aluminum for Centrafuse
    Constant Bitrate Meta's Avatar
    Dec 2004
    Indiana
    Finally, here it is. Brushed Aluminum.
    "Black & White" 848x480
    "Black & White" Stretched 800x600
    PS. The skin.xml file is essentially the same as that for BrushedMetal, except I changed all the fonts to "black/#000000". Doing so, I just now noticed that the OSK background and font now are BOTH black. For now, just change one or the other yourself in the OSK section. I'll post a fix later on.
    -Meta
    qaz
    qaz is offline
    Oct 2004
    i just tried this and attached a pic of what it looks like. theres text and icons on the left sides. any ideas? thanks
    Jan 2004
    Jersey/NY
    the text on top of the icons is too hard to read... especially when you're driving and you want to see what it is in a quick glance..
    other than that, looks great.
    Dec 2004
    Indiana
    Quote Originally Posted by qaz
    I think that's a bug in CF. Sometimes, when you load up a new skin, the "text" on the global nav buttons comes back. You shouldn't see any text, as it's turned off in the skin.xml file... you should only see the icons.
    Try exiting CF and restarting it. That usually does the trick.
    -Meta
    Variable Bitrate Osiris's Avatar
    Atlanta (kennesaw) GA
    Besides the original skin this is my favorite Centrafuse skin to date. Will be trying it out tommorow.
    Osiris Networx
    --Tuning is all about price vs performance. You've got to find your own medium.--
    Jun 2004
    The North, Manchester
    does it have all the screens?
    Constant Bitrate skydiver's Avatar
    Nov 2004
    southampton (UK)
    i get this when i pick destinator
    Program aborting close all that you have worked on,You ask to much. You step into the stream,but the water has moved on, This page is not here. Chaos reigns within, Reflect,repent,and reboot.Order shall return
    The car
    Nov 2004
    St Louis
    Quote Originally Posted by skydiver
    It doesn't have the destinator skins done and I have attached a modified copy of the skin.xml to fix the phone support. I only changed the settings for the phone so you can replace the original skin.xml with this one. OBTW, I did change the OSK, too.
    Attached Files Attached Files
    Dec 2004
    Indiana
    Quote Originally Posted by OriginalNick2
    Everything except, as the next post points out, Destinator. I didn't know this used a seperate skin either. I'll check it out.
    Dec 2004
    Indiana
    Quote Originally Posted by GizmoQ
    Hey, GizmoQ, thanks for doing the phone section in the XML. That helps tremendously and I'm sure many others will appreciate it too. I'll bundle it into the download packages this afternoon.
  1. Where to find Brushed aluminum?
    By legend5761 in forum Fabrication
    Last Post: 09-16-2005, 11:49 PM
  2. Replies: 41
    Last Post: 03-08-2005, 06:17 AM
  3. Bending aluminum into a case.
    By Giuliano in forum Fabrication
    Last Post: 03-02-2005, 08:41 PM
  4. Grey Screen when using Brushed Aluminum Skin?
    By Sid3ways S13 in forum FrodoPlayer
    Last Post: 07-23-2004, 01:17 AM
  5. WTB : Sheet of Brushed Aluminum
    By arcane004 in forum Classified Archive
    Last Post: 02-05-2004, 12:17 PM
