Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Blue Ice WS *NITE*
    Raw Wave tj!2k4's Avatar
    Oct 2004
    Blue Ice WS *NITE*
    I know a couple of people have been complaining about the brightness of the default Blue Ice WS skin at night, so here's my take on a night version. (the skin is better quality than the screenshot, don't worry..)
    Enjoy..
    Download here
    VENDOR - Centrafuse veetid's Avatar
    you can simply click the dim button in the bottom global nav... It will provide three different levels of brightness... When the darker modes are applied it looks a lot like your screenshot... I always leave it dimmed in my car because I like the skin darker also...
    david
    Oct 2004
    True; I just figured that this is a darker "starting point" for those who are more sensitive to the light..
    Raw Wave justintime's Avatar
    Apr 2005
    For some reason the CF 'dimming' feature tends to shift colors too much -- not sure what its doing, but it doesn't look right to me.
    The solution I am shooting for, is to configure a special 'night' setting in PowerStrip (by changing the brightness and gamma settings, I think this is all done in hardware) and then find a way to 'toggle' between the powerstrip 'default' and the 'night' settings from within CF. Might involve some clever scripting, will look into this.
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
    the dim functions set the gamma on the video card... it looks different on different video cards.. The darkest level does start to mess with the colors... The second level doesn't look bad on my M10000 to me...
    I might should look into adjusting the gamma and brightness... I think once the gamma gets to low and the brightness is still up, the colors start to mess up...
    david
    Apr 2005
    David,
    OK, so you *are* actually varying the gamma settings? Cool. Here is my suggestion:
    1) Tweak both gamma *and* brightness
    2) Make the values configurable, at least on the INI file.
    Speaking of making things configurable, I *LOVE* that everything can be tweaked through the settings dialogs, but I also think that by doing that you might be limiting yourslef. (i..e. I can see how you might not want to add the feature to tweak something, because you would need to add it all to the interface etc. versus just allowing us to tweak an xml file) Thoughts?
    2002 Honda CR-V
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    Yeah, it also makes iGuidance nearly impossible to see if you have it set to auto day/night..
    Constant Bitrate Meta's Avatar
    Dec 2004
    Indiana
    I'll post this in the 'feature requests' forum, but I vaguely recall discussions about the "DIM" button being configurable to act instead as a day/night skin toggle switch.
    Maximum Bitrate Vchat20's Avatar
    Jan 2005
    Warren, Ohio, USA
    actually, i like the modified skin alot. just loaded it and it is easier on the eyes. and ive got a slight migraine right now so that says quite a bit.
    Your everyday carpc geek and tech guru at your service. *bow*
    Apr 2005
    Quote Originally Posted by Meta
    I seriously doubt it.
    2002 Honda CR-V
  1. Red Ice WS
    By liquid_smoke in forum Centrafuse
    Last Post: 07-16-2005, 01:29 AM
  2. FS: 00-03 Nissan Sentra Blue Tinted Tail Lights
    By migel628 in forum Classified Archive
    Last Post: 06-13-2005, 06:02 PM
  3. WTB 40*4 blue backlit, inverted LCD...
    By never_stock in forum Classified Archive
    Last Post: 01-23-2005, 04:45 AM
  4. Neopolitan Ice Cream - LIKE IT OR HATE IT???
    By Scouse Monkey in forum Off Topic
    Last Post: 11-28-2004, 02:43 PM
  5. 24G Blue Empeg With Tuner 2 remotes (Re-Post)
    By belezeebub in forum Classified Archive
    Last Post: 03-07-2004, 01:00 PM
