looks good...
david
UPDATE! Version 1.05 is here. Fixes a 'resize' bug with the sliders and pause buttons, and also improves the OSK with larger fonts, and other tweaks to OSK.
Here is my release of the amber/orange skin for CF 1.4.
I'm calling it Orange Heat. It has a HONDA logo, but you can easily change this to include your own logo, now that CF supports PNG transparency.
Also, the Clock area has been extended, so you can overlay temperature readings using MotherboardMonitor5 like this.
Lastly, this skin is slightly optimized for 800x480 resolution. The Cover art will appear perfectly square in the Music playlist. (I pre-stretched it a little, so it looked right when scaling from 848x480 to 800x480)
Note: This skin is a slight step back from the original one I had created for v 1.3. It does *not* contain larger windows, and also, it does not change the main button fonts. There are way too many XML config changes involved to make those modifications, and it is not easy to support this from one version to another. Sorry!
>>>Donwload Orange Heat skin here<<< (2 MB .zip file)
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
looks good...
david
i knew you wouldn't be able to resist![]()
does that mean i'm back on the brushed metal project?![]()
Brushed Metal for Centrafuse 1.4
Brushed Aluminum for Centrafuse 1.4
xenarc 700ts | via epia-m10k | audigy2 nx | holux gm-210 | usb wifi | 40gb 2.5" | slot-load dvd-cdrw | morex 3688 | opus 150w | centrafuse, iguidance
You better be!![]()
2002 Grand Am progress :
[••••••••••••••••………] - 80%
...complete setup, but still need to make the install cleaner
thanks alot justin, now i'll go ahead and install 1.4![]()
Mazdaspeed Car Computer
gotta redo it all
I noticed that the sliders in the mixer and the pause icon doesn't resize properly at low resolutions so I edited the image DPI settings to fix it. Just extract the rar into the screens directory and overwrite the files.
justintime: I hope you don't think I'm stepping on your toes by uploading this. It is truly a great skin!
I believe this problem appears *only* when using 848x480 resolution. I have no idea why, but I know others making their own skins have the same issue. It does not occur with the native Blue Ice skin however.
I hope David can shed some light on the issue.
2002 Honda CR-V
not really sure what the problem is... the slider size in the skin file should be set to the same size as the actual file... you need to make your slider file the size it should be in the default resolution... When I see that the specified resolution is the same as the native resolution of the skin, I do NO resizing of any images to increase load time and save memory, etc... I assume all images are the actual size that is specified in the skin...
david
i also had that problem.
change the buggy screens to 96dpi instead of the normal 72, it'll work. remember to keep the image dimensions though.
had to do it on my pause buttons for dvd and media. also had to do it on the sliders.
works great now.
Ah! So, Dave, why are you using 96 dpi on these images?![]()
2002 Honda CR-V
