Cant seem to get 1.5 skins to work
I have tried a few skins now (Audi MMI 1.5, Brushed_Metal, a few others) for Centrafuse 1.5 and each time I try them I just see a mostly black screen or sometimes a black screen with some of the blue default icons/buttons on it but I can not click on anything. I have to kill Centrafuse and then edit the settings file or rename the directory containing the skin I had previously set to use to something else so that the default skin is again chosen. If I start Centrafuse without changing the entry in the settings file Centrafuse opens up in the top 1/4 of my screen (800x600) and is just a black box and will do absolutely nothing, I again have to kill the application manually through taskman. I have checked the log file and I get the following when openning up Centrafuse with a non-default skin...
1/10/2006 2:27:19 AM
Input string was not in a correct format.
at System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info)
at centrafuse.ImageSkins.readSplash()
at centrafuse.splash.CF_localskinsetup()
at centrafuse.Plugins.CFPlugin.setlabelskin(String whichlbl, Boolean useglobal, MouseEventHandler clickEvent, MouseEventHandler downEvent)
Value cannot be null.
Parameter name: image
at System.Drawing.Graphics.DrawImage(Image image, Int32 x, Int32 y)
at System.Drawing.Graphics.DrawImageUnscaled(Image image, Rectangle rect)
at centrafuse.cfbase.OnPaint(PaintEventArgs e)
Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
at System.Collections.ArrayList.get_Item(Int32 index)
at centrafuse.Plugins.CFPlugin.CF_updateText(String labelName, String text)
skins/Audi MMI 1.5/icons/folder_icon.png
at System.Drawing.Image.FromFile(String filename, Boolean useEmbeddedColorManagement)
at System.Drawing.Image.FromFile(String filename)
at centrafuse.ImageSkins.readImages()
etc etc. these lines continue to grow as long as centrafuse is open (but non functional). Does anyone have any idea why it is, when I try any skin other than the default one, this might be happening?
Gumby
