Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
Thread: The Skin Options Request Thread
    Variable Bitrate mercury7's Avatar
    Jul 2005
    Dallas
    This thread is for requesting features related to skins.
    Note: Do not request specific skins here, only features that Centrafuse currently doesn't have.
    I'll update this post with the requests as they come in.
    So, here's what I've heard:
    • Skin Editor
    • Ability to have a music progress slider
    • Ability to use static menu buttons - no drop-down
    • Ability to use images on selection highlights instead of gradients
    • Ability to have fast forward and rewind buttons
    • Ability to display "feeds" within the skin - Current speed, CPU temp, GPS heading
    • Full transparency - so you can see through to the desktop if transparent PNGs are used
    Post up, people -- help make Centrafuse the best!
    2002 Grand Am progress :
    [] - 80%
    ...complete setup, but still need to make the install cleaner
    Jul 2005
    Dallas
    In my eyes, "ability" from the above post would mean that if a certain line of code is in the skin XML, the feature is enabled, otherwise it would be disabled.
    So, if the default skin doesn't use certain features, it just wouldn't include that block of XML, and the rest of the program would function just fine.
    [] - 80%
    VENDOR - Centrafuse veetid's Avatar
    I believe you can use a static menu now that I think about it... If you put the 6 main buttons on the left, with on arrow key above and below it, that should work...
    This would make those always show on the left and be static... Then you could use or not use the top menu button...
    I want a skin editor too
    Looking into progress bar...
    Only handful of people seem to want the fastforward/rewind buttons back, most seemed to not mind the new method... We also made the buttons a lot bigger...
    david
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    nice idea about static menu
    RE: skip buttons...
    maybe if you made the button change icon once it went to FF mode it would help, maybe have FF activated by dbl click, and a click to carry on playing.
    Raw Wave justintime's Avatar
    Apr 2005
    I read this 6 times, and I still don't understand what you mean by this. I am very interested in getting this straight, can you elaborate when you have 2 mins?
    Thanks!
    Quote Originally Posted by veetid
    david
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
    Aug 2004
    Black Hills, SD
    The 6 main buttons are the ones with the icons that are in the center area. Someone has already tested that if the app/plugin doesn't cover them they are still usable. So if you move those buttons to the left for example and reduce and shift the main area to the right you can click them from any area. The only problem with that is you would have to include the arrows somewhere as the main buttons have upto 18 assigned actions to them.
    Hardware: VIA Epia MS 12000, 512 DDR, 60GB HD, 7" Xenarc, GM-210, Wi-Fi, Bluetooth, Radio Xtreme
    Software: Centrafuse2, Phonecontrol.net, nLite, TopoUSA 5.0, iGuidance, Girder, Winc
    Apr 2005
    OK, got it now. I missed the part about this being the main buttons! I thought he meant the main menu buttons, so nothing made sense to me.
    OK, so that's cool. Might be a workable solution.
    2002 Honda CR-V
    Jan 2006
    Lexington, KY
    Would it be too hard to code an option in setting menu where you would choose which buttons will show?
    Aug 2004
    Black Hills, SD
    Quote Originally Posted by Jay_1.8t
    You could code the skin itself you can set the width and height to zero and place it in one of the corners. It would basicly be doing the same thing.
    Just make sure you don't set any button actions to that button else you won't see it.
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    Skin feature request: Ability to display "feeds" (Meedio terminology) within the skin. For example, a GPS plug-in could publish a MPH feed and then a skin could place it where ever it wants.
    ...or is this already how song-title, time, and other such text work?
  1. skin request
    By refuse in forum FP Skins
    Last Post: 02-22-2006, 06:40 PM
  2. Skin Presentation Thread
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-27-2004, 08:44 AM
  3. Skin Presentation Thread - Spinoff :)
    By gubon13 in forum FrodoPlayer
    Last Post: 05-23-2004, 08:46 PM
  4. Replies: 3
    Last Post: 01-07-2004, 12:52 PM
  5. Arby Skin - Feature Request
    By nolmscheid in forum Software & Software Development
    Last Post: 11-11-2002, 07:10 PM
