Page 12 of 23 FirstFirst ... 2345678910111213141516171819202122 ... LastLast
Results 111 to 120 of 228
Thread: Nexus Skin for Centrafuse
  1. #111
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    I would be using RoadRunner if you had not released it JIT. (I'm still investigating RR, your skin just makes it much less a priority. I just wish CF was as stable as it used to be before the RC's... LOL)
  2. #112
    Nov 2004
    Its a very good skin.
    Will use it if I can get the destinaton frame in the correct resolution.
  3. #113
    Nov 2004
    L.A.
    JIT: Is it possible to remove the title-bar from full-screen video and show the normal top-bar instead? (see pic)
    I don't like how the exit button moves to the opposite corner. I also would like to see more of the video by splitting the overlap distance between the top and bottom (rather than covering a large portion of the bottom alone).
  4. #114
    Raw Wave justintime's Avatar
    Apr 2005
    RPM:
    I don't know that it is possible to do what you describe. The video_off.png file contains all the elements from the video screen, and I see no way of having a portion at the top, and another portion at the bottom. CF does not support making the center part transparent, which is what would be needed here as far as I can tell.
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  5. #115
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    it may have been mentioned already but I noticed that when in 800x480 (and maybe others) the NAV screen has its top row buttons from OnyxSkin and they are extended beyond 800 pixels wide as the fullscreen button half disapears off the screen.
    Non of NAV menu's seem to be skinned either
  6. #116
    Apr 2005
    Shawjohn:
    Read FAQ on first post. Nav screens (and few others) are not skinned.
    2002 Honda CR-V
  7. #117
    Aug 2004
    On the edge!
    sorry, didn't read the posts properly
  8. #118
    Nov 2004
    L.A.
    JIT: I understand the limitation in full-screen video. (sux )
    In the same boat though... I would like it if you changed around the media-manger screen to put the "X" button in the upper left instead of the lower right.
  9. #119
    Apr 2005
    Quote Originally Posted by RPM_VR4 View Post
    But why? I thought I kept it fairly consistent throughout the app? Tope left is for main menu, bottom right is for 'back to previous screen'.
    no?
    2002 Honda CR-V
  10. #120
    Nov 2004
    L.A.
    ...but bottom right isn't "back to previous screen" for anything other than the media-manager and the full-screen player. Plus, those are the only two screens that don't have a "link to the main menu". Therefore, it seems logical to place the "back to previous screen" in the same spot as the "link to main menu" for those two screens.
    Honestly I'd rather keep the normal top bar always visible even in those two screens. I realize that would not work for full-screen video as you could not make it disappear after 5 seconds, but can you bring back the top bar in the media manager?. I'd be happy with the "X" button where it is if you shortened the whole thing to make room for the top bar. On second thought, if you kept the top bar I would place the "X" button at the same co-ordinates as the "Media-Manager" button in the Now Playing list.
    ...anyway, just my opinion
    Question: Is it possible to change the function of clicking the top title-bar? (do something other than go to Media-Manager)
    EDIT: I guess "Exit" is in the bottom right of Settings too. Can you add the top-bar in settings? I really think it would be best with a truly ALWAYS-up top-bar. The existing "Main Menu" button in the upper left could instead be a "back" button which would always take you to the main-menu anyway within 1, 2, or worse-case 3 clicks in the exact same area.
  1. Mauri RR skin
    By mauri in forum RR Skins
    Last Post: 12-06-2007, 10:50 AM
  2. Red highlights for BMV2 Skin done
    By Mad Ad in forum RR Skins
    Last Post: 10-17-2006, 01:41 PM
  3. RR Web Cam Skin Help
    By babyface in forum Road Runner
    Last Post: 04-03-2006, 09:03 AM
  4. Skullster Skin.. Please help me finish this skin
    By CdRsKuLL in forum RR Skins
    Last Post: 08-05-2005, 09:37 PM
  5. finnaly skin uploaded
    By liquid_smoke in forum ME Archive
    Last Post: 12-31-2003, 10:13 PM
