Page 21 of 23 FirstFirst ... 11121314151617181920212223 LastLast
Results 201 to 210 of 228
Thread: Nexus Skin for Centrafuse
  1. #201
    Jun 2005
    Phoenix, AZ
    Can you post any modifications you made to iguidance? I can not get mine to look correct in 640x480. I am using 3.0 UMPC.
    You said your using skin bedder, isn't that an old app?
    Obviously you are using your skin & the theme file? Anything else I should know about?
    Scott
  2. #202
    Raw Wave justintime's Avatar
    Apr 2005
    spdyscotty:
    I am only using:
    1) My Nexus skin for CF
    2) My Nexus hack for iGuidance (are you missing this one?)
    3) My custom IG theme.ini file, which has better proportioned text and road width, as well as Nexus matching colors.
    4) SkinBedder, to embed it into CF nicely and without distracting windows menus etc.
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  3. #203
    Mar 2007
    Hmm, I finally got CentraFuse working and iGuidance, how can I hide the music control buttons at the bottom so I can see more area of iGuidance? Also, would anyone be kind enough to tell me the default values for the Centrafuse iGudiance plugin as far as the x y cordorinates?
    Appreciate your help.
  4. #204
    Apr 2005
    Did you read the FAQ in first post? You need to tap on the FAR LEFT side of your screen to make it go full screen while in iGuidance mode....
    Oh wait, you're using the iGuidance plugin? Sorry, in that case I am not sure about hiding the lower buttons while in Navi....
    Quote Originally Posted by htsource View Post
    2002 Honda CR-V
  5. #205
    Mar 2007
    Thank you for your response, much appreciated. I'm going to try without using the plugin. Sorry I was up late last night so my brain wasn't thinking very well.
    Very nice skin BTW and appreciate all your effort to share.
  6. #206
    Mar 2007
    Okay, I finally got something working, however, I still not be able to show just a full map like this one:
    http://www.mp3car.com/vbulletin/atta...-snag-0006.png
    I tried taking out all the buttons from the iGNexus.ini file but still the map size is the same. How do I make the map to fill like your?
    Thank you very much for your help.
  7. #207
    Apr 2005
    htsouce:
    You are using SkinBedder, right? You will need to use a different SKinBedder ini configuration if you want it to look like my screenshot. I can send you the config files if you want. send me a PM with your Email Address.
    2002 Honda CR-V
  8. #208
    Apr 2005
    Updated for compatibility with CF 1.12 !
    Check first post as usual.
    2002 Honda CR-V
  9. #209
    Constant Bitrate Lazyflip's Avatar
    Mar 2005
    FL
    I just noticed that if you play a playlist it shows the name of the playlist instead of the file type you're playing under the scrolling title. It seems to only show a max of 4 characters. I think it has something to do with a character limit but I'm sure you can easily fix it. Just you giving you a heads up.
  10. #210
    Variable Bitrate bns2000's Avatar
    Nov 2004
    Russellville, AR
    Justintime, Are you still making this skin or maybe a new one?
    CENTRAFUSE™ From Flux Media
    The Ultimate Infotainment Interface
    Download V1.20 from there site now!!!!
    Download the new 2.0 RC1 From here Linky
  1. RR Web Cam Skin Help
    By babyface in forum Road Runner
    Last Post: 05-20-2013, 03:47 AM
  2. Mauri RR skin
    By mauri in forum RR Skins
    Last Post: 12-06-2007, 09:50 AM
  3. Red highlights for BMV2 Skin done
    By Mad Ad in forum RR Skins
    Last Post: 10-17-2006, 12:41 PM
  4. Skullster Skin.. Please help me finish this skin
    By CdRsKuLL in forum RR Skins
    Last Post: 08-05-2005, 08:37 PM
  5. finnaly skin uploaded
    By liquid_smoke in forum ME Archive
    Last Post: 12-31-2003, 09:13 PM
