Results 1 to 10 of 15
Thread: New Media disposition purpose
    FLAC coucouillu's Avatar
    Nov 2004
    FRANCE
    Here is what i would suggest in order to increase visual size.
    What do you think about?
    Nov 2004
    FRANCE
    Files
    Joined files only for test this dispostion of button and Viz size.
    1) Make a copy of Night Skin
    2) Rename the folder like you want. (like "Onyx WS Night BigViz")
    3) Replace the old .png and .xml files by the ones given.
    FixedSkin2.zip for old versions
    skins_CF_1.2.zip for 1.2 version
    [Thanks to Duranike for Skin edition and skin fix]
    Attached Files Attached Files
    Aug 2005
    I like the look of it. I've always thought the album art display window was too small and I'm not keen on switching between full screen mode "on the fly"
    Dec 2006
    do you have any updated graphics? do you want me to make some?
    also can you explain further why the two picture files are the same?
    Great work man
    Nov 2004
    FRANCE
    Quote Originally Posted by duranike View Post
    hi duranike,
    as you can see my work is MS PAINT maid
    it would be kind of you if you could improve it. perhaps you have a better skin solution to increase the Viz screen size.
    Sorry but could you explain the probleme?
    Dec 2006
    actually i think i might. If i make the graphics can you help/explain/point me in the right direction on how to code it? Im a desinger and a coder, but im new to centrafuse, so i dont know the details of editing the skin.
    Dec 2006
    nevermind i figured it out. ill have two new versions of this soon.
    Dec 2006
    Got it
    ok attached is a zip with two variations of the mod stated above.
    I didnt do much but retouch the graphics so they look better.
    Two folders in the zip; Left and Right
    Left, is the one im going to use so the skin.xml buttons are perfect!
    Basically i took the ideas above and just put the buttons in the order of up, down, favs, and then the normal order of library and so on.
    Right, the xml in the file is the same xml file in the zip above.
    If your a perfectionist, then you should tweak the button hit areas a little since my graphics are slighty different then the one the xml was intended for. Basically the buttons are the same as the image above.
    Hope that makes sense.
    *****Now i mentioned in another post, but i guess this page/section of centrfuse (the music player) shares setting with the media art picture viewer. So im not sure if that can be different setting. If no, ill make another graphic for picture/slideshow. If yes, i wouldnt mine keeping the slideshow image the same.
    J
  1. Software Review: Windows XP Media Center 2005 Edition!
    By nFiniteTuning in forum The Review Palace
    Last Post: 05-01-2007, 12:54 PM
  2. Shutdown media engine
    By supergeek in forum Media Engine
    Last Post: 08-11-2006, 10:18 AM
  3. Windows Vista W/nView!
    By 97GST in forum Operating System Optimization
    Last Post: 04-01-2006, 09:46 PM
  4. Beyond Media out tomorrow!!!
    By Defiler in forum Software & Software Development
    Last Post: 12-04-2004, 02:27 AM
  5. neocar media center EN version, here it is :)
    By netsuo in forum NeoCar Media Center
    Last Post: 10-04-2004, 01:36 PM
