Results 1 to 10 of 19
Thread: Datalux LMV10R 10.4 Inch Touch Monitor
    Oct 2001
    Anyone interested in a fairly new/ hardy used:
    i can also include a rotating stand used for this monitor, plus all the cables and power needed to go with it.
    I need a resonable offer though in order to sell.
    email me if you're interested
    thanks
    -pete
    Monitor: http://www.datalux.com/monitors/lmv10.asp
    Stand: http://www.datalux.com/monitors/mountings.asp
    Swivel Mount
    For monitors: LMV10, S12, LMX12, X14, X15
    Weight: 2.42lbs (1.10Kg)
    Size: 4.25"L × 4.25"W × 8.5"H (10.80cm × 10.80cm × 21.60cm)
    Options: Shown above with 6" tall riser (SVP) for LMV10; also offering a 9" tall riser (SVP9) for 12" and 14" monitors
    Movement: Tilts monitor to a vertical position, and smoothly tilts backward 90°, arriving at a horizontal position. The plate, which is attached to the monitor, rotates freely and independently from the base.
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    This is the new one right? I'm not going to have some issue with it needing 5 volts instead of 3.3 right?
    Also is it a resistive or capacative touchscreen, and what is the brightness?
    Oct 2002
    I'm interested, how much do you want for screen without the mount?
    Ivan
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    I'd give you 225 if it was, in fact, a LMV10R. I sent my other one back.
    Oct 2001
    this is definitly a R
    no extra PCI controller card, just right into VGA
    email me your request, i have several already.
    thanks
    pete
    Oct 2001
    5 volts power
    resistive touchscreen
    pretty new, barely used
    i'm the first owner
    great condition!
    includes all cables and even the mouting swivel stand
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    sorry I meant LMV10R2
    Oct 2001
    ok, now i'm confused.
    i know it's the latest version, the one where all is required is power and a vga signal. i know it's NOT the monitor where you need an external controller card. it's very simple to setup, everything is fed through a single cable that goes to the back of the monitor. rest plugs into power, vga and serial port
    i hope this helps, i can look up the model number if you're really interested
    same one on the website
    -pete
    Jul 2002
    Houston, TX
    you wanna trade for a 12.1" touchscreen?
    I also have a 4" and a 5" RCA LCD...
    Oct 2001
    sorry, can't take any trades right now
    i just sold a 12 inch touchscreen
