Would this run off of a 12 volt battery? would i need an inverter?
Elo ELO 1545L USB Touchscreen LCD 15inch for sale. Dark gray, plastic bezel with metal back. Great resolutions 1024 x 768 at 60, 70 or 75 Hz
good brightness 300 cd/m2 and high colors
More info here:
http://www.elotouch.com/products/lcds/1545l.asp
Comes in great working order no damaged to the screen or damaged touch screen. Power supply and all cables included!
Would make a great incar screen with its high resolution and high brightness.
$400 plus shipping
This is also forsale over at [H]ardforums email me @ Jayelrod@attbi.com for fastest repleys.
http://www.theforumisdown.com/upload...0103/power.jpg
paste the url into the borwser ^
Im would assume so. Looking at the power deal its listed as 12v so it should run off any 12volt source fine.
is 400 a firm price?
Yea im trying to make back what I paid. I just recently bought it but it turns out its to big for my case so I need to sell it to buy a 10 or 12 inch. I have some more pictures but am looking for a place to host them. I may be able to go a few bucks lower but I just put it for sale on [H] this morning so ill give it some time since the price still is lower than most places, but most likely it will go to ebay in a week or so.
For example Ebay All starting at 400.
Here are some pics
Its much sharper in person the camera blurs it a bit
so there would be no problem with wiring it up directly to the battery? battery voltage varies from 11-14.4 volts. do you think that would harm it? thanks
The matrix - reloaded ? .. is it "out" ?(ts)
"If A equals success, then the formula is: A=X+Y+Z. X is work. Y is play. Z is keep your mouth shut."
Albert Einstein
No you need to regulate that, use a CPU for power!
you will mess something up!
BossTone74
well the opus is only rated at 5 amps, 6.5 max. that screen is rated (the power supply) at 5 amps. would this put too much load on it? thanks
