how long will you be selling them?? I'm not sure where my computer is going (under the seat or glovebox), so I'm not sure on the length yet. If not for long.. guess I'll get one that will reach to under the seat just incase...
I'm selling custom length IDE cable :
80 conductor wire IDE 66/100/133 cable with two connector (each end) for a hard drive or a CD/DVD-ROM
and
34 Condor wire IDE cablewith two connecor(each end) for a floppy drive.
each cable is
$2 per FOOT + $2 shipping (in US only)
**Minimum length is 4ft.**
maximum length can be up to 250 ft
every cable will be test for wire connection but I can not guarantee for working file signal transfer due to the expended cable length, there are many people tried extra long cable and had different result. I don't know how long is too long, so please don't ask me if it will work or not.
For any other question , PM me
Folling pictures are the actual cables and connectors
Click Here to go to the Order page
Cordell
Well I'm selling this as long as I have cable , I used some for my own project and already had some orders, I'm not exactly sure how long is left.Originally posted by Cordell
how long will you be selling them?? I'm not sure where my computer is going (under the seat or glovebox), so I'm not sure on the length yet. If not for long.. guess I'll get one that will reach to under the seat just incase...I'm sorry I can't give you exact answer
do you have any of this cable left?? I need about 5 feet with the 40 pin connector.
If do not have it, where can I get this??
I have run into this problem before.The maximum length for an IDE cable allowed by the ATA/IDE Standard is 18 inches; and that is the length of the cable that is supplied with most drives. In some cases, this 18-inch length may not be long enough to span the distance from the motherboard or IDE controller to the drive bay in which the drive is being installed. Although it’s possible to obtain or make a custom IDE cable with a length exceeding 18 inches, be aware that the devices attached to such a cable might not operate properly due to noise and/or signal attenuation. Possible problems can include anything from intermittent data errors to the drive not being recognized by the system. Proper operation cannot be guaranteed for drives that are connected to cables that exceed the 18-inch maximum length.
Doesn't it effect the datatransfere through the cable if you go and take a cable that long??
System in progress:
New install in progress...
has anyone been successful in using the IDE 80 pin wire 4 feet plus for a cdr or dvd?
92 Taurus SHO - Daily driver - Epia M10000 80GB 512mb 7" touchscreen, Opus PSU etc
93 Black SHO - 30mpg cruiser
90 Silver SHO - 419whp fun/project car, CarPC to come (for tuning)
I believe someone on here posted that they used a 20ft cable for DVD playback and it worked fine.
