FS: 10.4" BRIGHT LCD TFT MONITOR & KIT
Here it is.
All of it works, except I'm not sure about the touch overlay. The plastic covering on it that says "Datalux" on it was removed, and a copper "contact ribbon" was torn in the process. To fix it, you would need to solder the contact back together. I have no idea, but it may still actually work without doing this, since the only thing it does is help to prevent noise. Allen Ruble will vouch for that as well.
In any case, it's a damn nice screen, 350 nit, 300:1 with no bad pixels and very very bright. I saw someone else has an auction selling resistive touch overlays for $10 so that would be an cheap purchase if you didn't want to bother trying to fix it. But it is a capacitive touch overlay and it worked for me perfectly previously. Drivers can be downloaded from www.microtouch.com.
Pinouts for the controller will be included, but you won't need them, since I am including all of the necessary cables. The only connections necessary will be:
-Vga input from your video card
-Serial input from your motherboard (for the touchscreen)
-12V input from your car (yes, wiring directly to battery will work, the controller is designed to operate at 11-15 volts).
-5V input to turn the screen on (I had this wired to my PC's 5V rail so the screen would turn on when the PC did).
thanks
Looks damn skippy and comming from you, I would definatley look into get this screen if I needed it.
For those considering it, dont consider it, just get it now. Super Matty has helped me so many times I lost count. We constatly talk about our setups on AIM. Great guy, I would trust his word and judgement.
Definate recommendation from me.
Heh, okay thanks for the plug
*BUMP*
Not much time left for this awesome screen!
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
