Page 10 of 20 FirstFirst 12345678910111213141516171819 ... LastLast
Results 91 to 100 of 195
Thread: High Bright LCD
  1. #91
    Constant Bitrate SinnerG's Avatar
    May 2003
    Long Beach
    Blop-
    If you look at the second page of this post, You'll see two pics. The first one is the LCD1024E controller connected to the LCD panel. Maybe they don't 'officially' support it, but it works. Look again...
  2. #92
    Jul 2003
    Earth
    aah you mean the great big picture with a controller plugged in and the lcd working in a really obvious way!!
    I have had a chat with a guy at miles electronics and i have found a controller locally that will control both my panels....
    Thanks anyway.
    is there anything to look out for when buying controllers excluding getting the resoulotions you need and the connections....are any better quality than others?
  3. #93
    May 2003
    Long Beach
    What you need to do is figure out what the lcd's can do. The AllBrite LCD is an 18-bit panel ((6-bit/color) X RGB). It also runs at 3.3V. I'm not sure about the other panel, but voltage is more important than matching the 18-bit color scale.
    Look for a controller that has at least 18-bit color, but more importantly, make sure you have selectable voltage for the panel you are using.
  4. #94
    Jul 2003
    Earth
    I was reading that the dicon has jumpers for configuration something that would be ideal if it would offer a wide diveristy of voltages etc..
  5. #95
    Maximum Bitrate eCar™'s Avatar
    May 2003
    SE Michigan
    Quote Originally Posted by Blop
    aaah DAMN...
    I cant belive that guy sold out i always miss out...
    He must have one more
  6. #96
    May 2003
    Long Beach
    Look at this post. There are more....
    Quote Originally Posted by eCar™
  7. #97
    Maximum Bitrate ddogg_777's Avatar
    Apr 2003
    HOT Arizona
    I think what he ran out of are the displays with the inverters. I can't believe people are paying so much for lcds without the inverter! Didn't it get to like $70!!! Don't screw yourselves guys! Those 4-bulb inverters may be well in the $100 range. Also, these displays give off quite a bit of heat, they are not ideal for some mobile applications. They are also very bright and I have yet to be able to dim the brightness. Anyone else get it to dim?
    Quote Originally Posted by SinnerG
  8. #98
    Jul 2003
    Earth
    Any one have a supplier for those lin finity inverters....
    yes it was i that paid 70 bucks.......
    I got carried away....
  9. #99
    Jul 2003
    Earth
    Hows the dimming going?
  10. #100
    Apr 2003
    HOT Arizona
    I can't imagine why it is not working...I even connected a voltmeter to the brightness control lead and I can verify it is changing from 0V to 3.7V (All while watching a movie on the lcd). I was hoping SinnerG would ask the folks at Microsemi if their is something we need to know.
