Do you think Mark will take the busted one back?
I finally got the cables and connected my setup. I was pretty amazed at the viewing angle (nice and wide...woohoo), as well as the brightness. As it turns out, though, only one of the two LCD's worked. The file I made up is correct. I'll post some pics soon.
I sure hope he'll stick to what he told me....no DOA.
can't wait to see the pics
FEEL THE RUSH
P4 1.7, 1gb sdram, 40gb 7200, ati dual video, 5.6" In dash, 13" lcd touch screen in back.
96 gt conv. Mustang
Hey sinnerg, that inverter uses a 0-2.5V trim for the brightness control but your controller board provides 0-5V. Have you tested these functions to see how they work and/or did you add a resistor to drop the voltage. Also, did you just buy the hirose connectors from the place you mentioned and then just made the cables with ribbon wire?
I was looking at that last night....the differences in the input voltage to the inverter, and will put together either a pair of same valued resistors or a potentiometer to drop it down to 2.5V. Although the 5V input from the controller to the inverter lit up the backlights OK, I don't want to end up frying the inverter. This could explain why I am getting a 'flicker.' I initially thought it was a refresh rate problem, but it could be the input voltage to the inverter. We'll see.
As for the cables, I had them completely made. When I got them, it was nothing more than plug and play. Personally, I would recommend going to this company for the cables. It's your choice. Send them the file I posted earlier for a quote. It has both the controller->inverter cable and the controller->LCD cable in the file. But this is for my Dicon controller. If anyone else plans on using a different controller, you'll have to do some research for your own setup.
Although these don't give you the 'full effect,' it's something to compare to. These are a few pics...............
did you get the other lcd to work
FEEL THE RUSH
96 gt conv. Mustang
can you take a pic with the lcd screen with some light on it ?
reason is i need to make sure it will work in my convertible
thanks for your time on these posts
FEEL THE RUSH
96 gt conv. Mustang
