Page 8 of 20 FirstFirst 123456789101112131415161718 ... LastLast
Results 71 to 80 of 195
Thread: High Bright LCD
  1. #71
    Maximum Bitrate ddogg_777's Avatar
    Apr 2003
    HOT Arizona
    Okay, I have an update for all those who have been following my brightness control idea. My dicon controller has a voltage control for backlight brightness, 0V-5V, but the Linfinity inverter that we all have only needs 0V-2.5V for the full dimming range. I did put in a 470Kohm resistor and it dropped the max 5V down to 3.8V. This should be adequate because the inverter datasheet says it can handle a 6V max. But, if you want a finer range to deal with when adjusting the backlight brightness, try a higher resisor to bring it closer to 2.5V! I tested the voltage range and it went from 0V to 3.7V. The strange thing is...I don't notice any change in the backlight display as I varied the value! Any suggestions or does anyone have a different experience?
    SinnerG, wasn't it you that said you were getting some flickering? Did you solve that? I have the v-sync from the inverter hooked up with my lcd panel v-sync, it works great! No flicker. I just soldered the lead from the inverter to my hirose cable.
  2. #72
    Constant Bitrate SinnerG's Avatar
    May 2003
    Long Beach
    I noticed the same thing on the LCD1024E. There was Brightness control on the OSD, but it didn't do anything. I was just looking at the datasheet for the LCD1280EI. Make sure on JP2 (page 11 of datasheet), that the Dimming Control is set to internal PWM.
  3. #73
    Apr 2003
    HOT Arizona
    Checked, but I decided it can't be the controller board, it has to be the inverter. This is because the brightness voltage IS varying like it should from 0V to 3.7V (I checked with my voltmeter) when I use the osd, but nothing happens on the inverter side. Oh well....
  4. #74
    May 2003
    Long Beach
    Have you tried the inverter that came with the Dicon kit? Does it vary brightness with the OSD? If the problem is with the MicroSemi invereter, I pay them a visit. They are really close to me.
  5. #75
    Apr 2003
    HOT Arizona
    I'll will give it a shot! Hey, Dicon and Microsemi are close to you? DANG! that's cool. SinnerG, do you need a 8-pin hirose for your microsemi inverter? PM me...
  6. #76
    May 2003
    Long Beach
    I was just checking www.microsemi.com and they don't seem to have their page up. I wonder if they still exist. I did call them the same week I bought the LCD's, but haven't since. I wish I had their address handy. I'll do some more searching...........
  7. #77
    May 2003
    Long Beach
    I found this.
  8. #78
    Apr 2003
    HOT Arizona
    I was just searching their website yesterday so it must be down for the moment.
  9. #79
    Variable Bitrate Sh0cker's Avatar
    Aug 2003
    LI, NY
    Hey, i red the entire topic ... everything sounds interesting, but how about the price - including every part needed to use lcd?
    SinnerG, ddogg_777 since your have those LCD up and running can you tell me the final price you spend on the lcd.
    I'm not sure if i should buy ready to uselcd for $325 OR spend some time and do what you did.
    I think would be very useful for me and the rest of the readers if you list the parts what you use with your LCD (part, place/website from you bought, price).
    Thanks in advance.
  10. #80
    Apr 2003
    HOT Arizona
    I spent $20 for the lcd and inverter, $130 for the lcd controller and all cables. Now all I need to do is make a nice housing.
