What's the story with USB? Someone said it is on the mobo but there's no port? Do we just need some sockets to hook up or will it require a USB card?
Chris.
I don't have any other chips to try right now, the technical docs seem to imply it is a standard Phoenix BIOS but with not other chip to try there's little benefit in me experimenting with that right now.Originally Posted by Blop
Chris.
To outragis or robiewp or anyone else who has already received theirs. Does the motherboard have a set of jumpers next to the riser card connector slot with
[SPKR:RST:SLP:PWR:HDLED:PWRLED]
on it like the pdf file for SPOS61 indicates? Is the PWR jumper simply shorted with a jumper cap? If so, easy enough to just pull that cap and hook up a switch there, eh?
Originally Posted by chut
The pins are there, there are no jumpers on any of them though. Can't tell you much more than that, getting a little low level for me!Originally Posted by MTWallet
C.
Just shorting the two PWR pins doesn´t do the trick ??Originally Posted by ukchris
Probably the culprit is the power suply, mayby it doesnı support being "controled" by the motherboard. Theres one way to be sure. Just plug a standard PSU, and try if you can switch on/off by shorting the PWR pins.
Brave
Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
Status --> Lilliput Installed (not indash yet..)
BraveCar 2.5
what theres a pdf? do u mean that zip linked from the ebay auction?
If not can someone post me a link to the pdf.
I tried a 700 celeron...No work, Then I tried a celeron 500...worked!
I have the motherboard brand at work, where the unit is, it is written under the board, went to the website, no updates...I will post name in the morning
Eric
I never said it didn't work, I said I was a little bit chicken to start shorting stuff, maybe tonight, just installing the OS on #2!Originally Posted by Bravellir
Someone here got them and forwarded me a copy, if you want to PM me your email address I can forward them to you too.Originally Posted by Blop
Chris.
here are some more pictures (including of the USB pins)
http://www.lawlis.org/kiosk.htm
car computer rev 5: 8" lilliput and usual suspects
