Page 93 of 93 FirstFirst ... 438384858687888990919293
Results 921 to 930 of 930
Thread: Found someting interesting on E-Bay!!!
  1. #921
    Mar 2004
    http://www.wizer.co.uk/gallery2/v/misc/kiosk.jpg
    This is the general idea, but I am waiting to hear about the cables before the final design
    Ideally id like to ditch the original case
  2. #922
    FLAC ukchris's Avatar
    Nov 2003
    Massachusetts
    You might be able to do something similar without extending if you put the MB back to back with the screen and the riser pointing toward the right angle int he triangular case.
    Study where the cables go, you should be able to remove the screen without making any permanent changes, just remember which plugs go where.
  3. #923
    Mar 2004
    cheers chris, i'll give it a go
  4. #924
    Mar 2004
    im just taking the kiosk apart and i'm struggling to find a way to take one of the metal supports off the screen. The screw is covered by the glass so I can't get a screw driver in there.. Is there a way to do this?
  5. #925
    Nov 2003
    Massachusetts
    You can remove the touch panel r try tto drill out the screws. You should be able to figure out if thswill workfor you before having to do that though.
  6. #926
    Jul 2003
    Earth
    Brightness control, please help!
    Hi i wonder if you can help me....im trying to make the brightness
    dimmer as described for the kiosk unit. I was intially follwing the
    one using a variable resistor...but after reading further i have found
    it doesnt work!
    So what kind of switches do i need? will these do?
    http://cgi.ebay.co.uk/4-QTY-RED-PUSH-BUTTON-
    SWITCHES_W0QQitemZ7555152779QQcategoryZ58169QQrdZ1 QQcmdZViewItem
    and if so how do i wire 2 switches that have a total of 4 legs/
    contacts to a 3 pin header? It doesnt make sense to me how i can
    follow this diagram with 2 switches each with 2 legs! many thanks!
    FPBRT_D_U
    o o o
    | | --- N.O. DOWN switch
    | ------ N.O. UP switch
    --------- COM of switches
    Is it possible to get a single switch that will do it all?
    Many thanks!!
  7. #927
    Low Bitrate petec's Avatar
    Mar 2004
    Midwest, USA
  8. #928
    Nov 2005
    Cool I know, old thread but if you have or had one!
    Looking for feedback from folks who did these kiosk computers.
    Was it worth it, performance wise?
    Did you mount it in your car?
    How did it look?
    Would you do it again?
    Tnx Fred
  9. #929
    Mar 2004
    Midwest, USA
    I purchased three of them and put TV cards in each of them. I upgraded CPU to 1.3 Ghz Celerons, memory to 512 and HD's to 40 gigs. They all work well. I am looking to mount mine in the house (bought them two years ago). The problem with mine is I would need to extend each of the LCDs around 6-8 feet and haven't done it yet. They all work well and never had a problem with them. I want to use them as extensions to my HAI and MM system in the house.
  10. #930
    Low Bitrate 99bravada's Avatar
    Dec 2003
    Fort Lauderdale
    Since I couldn't get my Kiosk PC to be ACPI compliant, I am now using my MSI Mega 180 SFF computer with the Sharp LCD that comes with the kiosk PC. I went out and bought one of the EarthLCD Analog to Digital Controller cards and it works great. I spent about $250 total and it's a matter of plug and play (tell them which LCD panel you have and they make the video cable that goes to the board for free.). I now can use VGA with the LCD and a standard serial cable for the touch screen. I highly recommend.
    I extended my cables originally and this worked fine, but my friend and I spent so much time soldering those pins on the video connector and it still looked ghetto... It's a lot of money to throw down to buy the controller, but it's the best way to go, for sure.
    Current:
    2011 Black Jeep Wrangler Unlimited Rubicon | 20" KMC Rockstars | 35" Nitto Mud Grapplers | Rugged Ridge XHD Front Bumper | Kicker KX350.4 amp
  1. some interesting stuff (links)
    By pinkysqueaks in forum General MP3Car Discussion
    Last Post: 08-04-2001, 12:28 AM
  2. mounnting an LCD in a floppy drive bay?
    By JustAGuy in forum General Hardware Discussion
    Last Post: 07-25-2000, 11:40 PM
