Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: New P4 system which fit into the single din slot
    Jul 2004
    This is the specs of the mini P4 computer and 7 inch touch screen.
    Intel Pentium 478 socket 533 Mhz motherboard (Max 3Ghz)
    Intel P4 Processor 2.4 Ghz
    256 DDR RAM 333Mhz
    40G Notebook Hard Disk 5400 RPM
    Slim DVD Combo Drive
    USB wireless LAN
    Mini casing
    19vDC adapter
    12vDC to 110-230w AC inverter ( continous 150w)
    Specification of the JPP 7 Inch TFT LCD Monitor with VGA
    16 :9 Wide Screen
    Swing & Flip down Function
    4-Wire Resistive Touch screen (USB Interface)
    Brightness, Contrast, Color, Phase, Clock OSD Adjustable
    Brightness : 300 cd/㎡
    Contrast : 150 :1
    View Angle : L&R 40 , Up 15 , Down 35
    Operating Voltage : DC 12V ~DC14.5V.
    Power Consumption : 12V / 850 mA
    1 VGA Input (D-Sub 15), 2 Video Input, 2 Stereo Audio Input.
    NTSC/PAL Multi-system.
    Support Resolution : 640 480 , 800 600 , 800 480 , 1024 768
    Physical Resolution : 800 (H) 480 (V)
    Dot Resolution : 2400 (RGB) 480 =1,152,000 Dots.
    Storage Temperature : -4F ~ +140F
    Operating Temperature : +32F ~ +122F
    Power : DC 12 ~ 14.5 Volts For Car use
    Dimension (cm) : (Width) 18.3 cm X (Height) 13.1 cm X (Thickness) 2.8 cm
    All this for only USD 1000.00 including shipping
    Jul 2004
    sorry! forgot to mention the size of the casing.
    width 17 cm
    height 5.5 cm
    depth 26 cm
    Variable Bitrate proTONEd's Avatar
    Jun 2004
    Belgium
    Nice gear you've bought dude!
    But beware of the depth of the case though. Most cars don't have that much room in their dashboard. Most headunits are only about 17cm deep...
    Why is it drug addicts and computer afficionados are both called users?
    Currently : Audi A6 - no install
    Second install : VW Passat '97 CarPC
    First install : '87 Audi 80 CarPC
    Jul 2004
    Most of the Japanese is suitable for this modification. Because of its small size, it can be modded anywhere ( very convinience)
    Low Bitrate Triad.:'s Avatar
    would you sell it without the screen?
    one more thing, I assume it could take an ATX power supply?
    Jul 2004
    The inverter can only take up to continous 150w only.
    If without touch screen, i think it will be around USD 800.00 including shipping.
    Mar 2004
    who is the computer made by
    thanks
    Jul 2004
    The computer is made by taiwanese
    Maximum Bitrate dodgetimes2's Avatar
    MI
    Isn't everything? tracker92 wants to know what company makes it, not what country it's made in.
    1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
  1. Help - Opinions on my DIY LCD case (single DIN)?
    By nxt125 in forum General Hardware Discussion
    Last Post: 04-14-2011, 08:28 AM
  2. Replies: 6
    Last Post: 10-21-2003, 03:33 AM
  3. has anyone fitted a carputer into a single din
    By bertybassett in forum General Hardware Discussion
    Last Post: 10-10-2003, 08:02 AM
  4. can I fit two DIN sized devices in my Ford Ranger?
    By parawing742 in forum General Hardware Discussion
    Last Post: 06-25-2003, 12:47 AM
  5. Help me understand PC in a DIN chassis
    By cproaudio in forum General Hardware Discussion
    Last Post: 06-11-2003, 10:51 AM
