Results 1 to 10 of 14
Thread: 1gb and 2gb compact flash cards for cheap at
    FLAC bosstone74's Avatar
    May 2002
    Japan, Oregon
    Just saw it
    thought I would share it
    I didn't look for the 1gb, I'm sure you'll find it
    but here is the 2gb buy.com
    BossTone74
    Jul 2004
    Irvine, Cal
    damn thats cheap
    Variable Bitrate choyak's Avatar
    Jun 2004
    Buena Park, CA
    That is the cheapest that I have ever seen a 2 gubbuh CF card and a good brand also!!
    Carputer currently 'ghettoed' into car!!!
    EPIA MII-12000
    Ampie Case with rigged extra USB
    Hitachi 60GB
    Holux GPS mouse with iGuidance 2.0
    Lilliput 7" touchscreen
    Netgear WG121 USB WiFi
    Carnetix P1260
    Mac Car Moderator kandyman676's Avatar
    Maryland
    makes you kind of wonder why its so cheap, yah know? plus they are not available; they have a 3-5 day ETA before shipping.
    "If it works this good why F with it?" -KMFDM "Intro"
    Strive for ethical wardriving: http://faq.wardrive.net/
    My CarCPUs: v1 - 2000 | v2 - 2004
    Mp3Car Meets: http://detrimental.org/eyecandy/MP3CarMeets
    FLAC ppgt94's Avatar
    May 2001
    USA
    That IS cheap (this week at least). I wonder how this would perform in my DRebel?
    Newbie hydraulix's Avatar
    Aug 2004
    Hialeah FL
    are these kinds of memory devices bootable?
    for example could I install my OS to it? would it help performance wise?
    Variable Bitrate brooksware2000's Avatar
    May 2004
    Minot AFB, ND
    with the right adapter, yes they are bootable. Performance wise, they don't have any moving parts so they are more ruggid. But, they have limited right cycles so you may want to put a read-only OS on them..
    Check out my hopefully useful site...
    www.hobbybotics.com
    It's still under design but it is functional
    Constant Bitrate mindscream's Avatar
    Jun 2004
    Memphis
    Quote Originally Posted by brooksware2000
    Gotta agree with that one. Although I've found that the write cycles are usually a pretty decent number, somewhere in the 1000's.
    What I'm planning on doing is having a CF boot drive and a hard drive for storage.
    NOW...the question for all you tech heads out there. What all of Windows 98 would have to be changed to make it a read only OS??
    More to the point, other than the pagefile.sys and the temp directories, what else would have to be changed to a D:\ to keep the write cycles down to a minimum??
    Please discuss...
    Mind Scream out
    May 2004
    Minot AFB, ND
    I think that should about do it. The biggest issue would be with an XP install since it costantly writes to the HDD. I've been testing a stripped down version of WinME for like 2 months and have not had a problem with it.
    www.hobbybotics.com
    Constant Bitrate Needstorage's Avatar
    May 2004
    Belgium
    Well, put this on a CF card, and your CF card will die, sooner or later. And I think it 'll be very soon. Windows always uses a swap file, and writes/reads it constantly.
    U could -however- use XP Embedded, with the EWF write filter. This allows to use the CF card read-only.
    Needstorage
    Who the hell is general failure?!?
    And what the f@#k is he doing reading my drive C:\?
