Up for sale are some lightly used PC components. All items were used over the span of about 6 months. I burnt maybe 10 cds on the Sony drive with no problems at all. Buyer will receive my complete contact info when a deal is made. I have positive feedback on ebay and other boards mostly selling firearms.
Antec True480, 480 Watt Power Supply $50 Shipped
Features:
Dedicated output circuitry for each voltage output, overcomes the limitations of combined output of traditional design. Get all the power you need when you need it most.
Voltage Feedback to maintain accurate voltage to all components: adds stability to your system
Antec Low Noise Technology achieves the optimum balance between noise reduction and necessary cooling.
ATX12V for AMD and Intel based systems including P4.
2 Serial ATA drive connectors.
Two double ball bearing fans.
Gold plated connectors.
Award-Winning TruePower Performance
PC enthusiasts and reviewers agree: TruePower is Antec's most advanced line of PC power supplies, with over 45 worldwide Editor's Choice or "Best Buy" awards and counting.
The Worldwide Leader in Silence and Performance.
TruePower from Antec is the most advanced line of PC power supplies from the company that has led the way in power supply design and quality since 1986. These power supplies feature dedicated output circuitry for each voltage so that each output delivers maximum power whenever you need it. To make sure these voltages stay accurate, TruePower also includes voltage feedback circuitry to improve system stability
Thanks to Antec New Low Noise Technology, system noise is substantially reduced, too. The power supply fans run at the lowest speed appropriate to load and conditions, controlled by an advanced temperature response system that outperforms previous solutions. Dedicated Fan Only power connectors allow TruePower power supplies to control the speed of case fans, too, thus reducing total system noise.
Sony CD-R/RW 5.25" drive model CRX225E $25 shipped
SONY CRX225E 52X/24X/52X E-IDE INT CD-RW W/ SW OEM
Sony CD-Rom Drive Unit Model CDU511 $9 Shipped
