what kind of power supply does it have and what is the power consumption of the entire pc?
The Power Supply Is Built Onto The Mobo..so I Cant Tell The Wattage...i Think I Read Somewhere It Uses Between 120 To 140 Watts..using The Inverter You Shouldnt Have A Problem At All. I Dont Have A Problem With Mine.which Is Included. It Has A Power Brick Which Is Also Included With It. Everything You Need To Power It In The Car Is Here. I Have A Bunch Of Usb Devices Hooked Up To It On A Nonpowered Hub And They Are All Running Just Beautifully. 1 Usb Port Is Extended To The Front Of The Car And Running A Nonpowered Hub For The Slim Dvd Burner And Gps. The Second Usb Port Was Used To Power My External Hard Drive. And The Other 2 Ports Werent Really Being Used Yet..i Was Gonna Add Usb Tv Tuner And Usb Wifi. It Can Be Done Without A Problem.
I'll take the Slim line dvd burner for $40.Originally Posted by EsKALad
make an offer!! i will entertain offers!
Ill take it for $200.00 just the computer.
You can still have something if you have nothing
no thanks..im looking to get more than that...unless you take it without ram hdd and optical drive..i MIGHT consider it if anyone else is willing to buy the ram and hdd and slot load dvd or the dvd burner..
