bump
Debating on installing a carpc in my Jeep.....
bump
FS: 9 Pin Mini Din Cables
Do you still have the cables. If so could I get a close up picture of either end to make sure it is the cable that I am looking for.
i should still have the cable lemme go take a quick look and ill be back with pics if i have it
ok i do still have both of them... here is a picture of the cable ends, and a quick paintshop pic of the pin layout (rough picture but close enough)
do you know if this will work with the 8 inch lilliput? if so ill take one
i got dat ***** sittin on 22s! SUPERMAN EDITION!
hmmm idk do you already have the screen? if so send me a pic of the connection, and i also look around for an answer on the forums
this is not the cable an 8inch lilliput uses, the cable they use is almost like a vga cable, but not quite
ok in the first picture its the black one in the middle that attaches the vga and usb, the rest are svid and cvideo inputs.
in the second pic thats the connector that goes into the back of the 8 inch lilliput. this might work. ill take better pics today n let u know
yes i just got confirmation from Armen of Dww and he said they do use the 9-pin mini din cables, so these should work
