Ive got a socket A Speeze CPU cooler....unused and unmodified. Should be good to cool an AMD Athlon XP. The box says "5T321B1H3G" on it.
I need an unmodified AMD heatsink and fan with the numbers MF035-032
BossTone74
i don't know if it helps, but i have a socket 370 fan for sale (wth cpu) if you are interested. check out my ebay page...
Ebay
I'm doing an RMA on my 2400+ and they requested that I send the heatsink along too...
the only problem is that I lathed it (sanded it) a bit for better contact and cooling. I don't think they will like that, I NEED the one with the #'s MF035-032
thanks for your help though!
BossTone74
i don't think they would care. as long as they get their restocking fee. I'd try to send it this way.
but they could also say that this was the cause of the failure...
BossTone74
it would be expensive, but you could buy a new one from a brick and mortar location, use the HSF from it for the RMA, then return the unused, working CPU with the lathed HSF. They arent going to check if its working fine.....
do they give you a new packaged on when you RMA to AMD?Originally Posted by jusatry
BossTone74
