DSCustoms DS700YYV 7" Color VGA Touchscreen LCD monitor. This monitor cost over $400 new and still works flawlessly. This is basically the exact same monitor as the Xenarc 700TSV, since the LCD screens are made by the same company, Gain. The monitor comes in its original box with all original accessories. There is a very slight gap between the front and back housing holding the screen in place on the lower left side of the screen. This gap is almost completely unnoticeable. The touchscreen drivers that will be included in the box are not on the original CD because I lost it, but the drivers are burned on a CD-R and are exactly the same as the original.
Here is the original information about the screen from the manufacturer:
Perfect for using your computer in the car as an mp3 player, GPS navigation system or a mobile office. The new touch screen control allows you to control your computer with a fingertip! Software included lets the screen work like a mouse, or use the on screen keyboard included with Windows.
If you have tried to use a computer in your car before, you have probably realized that the composite video signal used with all the other mobile video screens has problems. They are designed for playing movies and video games, not reading 10pt text. By using a VGA input, we have developed the perfect solution to this problem. The DS700YYV connects directly the the video card or onboard VGA port in your computer. The resolution is so good with this screen that you can read standard text at 1600x1200 resolution!! There is truly nothing else like this on the market. Touch screen drivers support Windows 98, ME, NT4, 2000, XP,. Also, Linux and DOS.
Mac OS-X Support should work with the newest drivers available. No guarantees can be made on software compatibility with OS X. The software for the touch screen is produced by EELY, not DS Customs.
Not only are these the best computer screens you can use in your car, but they also have 2 composite video inputs for your other sources. Now you can hook up your PS2, X-Box, Game Cube, etc... to this screen also. Switch between the movie your passenger is watching and the navigation software on your computer with the push of a button. You can set AV2 as priority which is great for the reverse camera to automically show up on the screen. It even has a built in speaker that you can use if you don't have a way to wire the audio from your computer or DVD player into your car stereo.
This is the top of the line model, brand new on the market, with improved brightness and touch screen sensitivity.
Package Contents:
1 DS700YYV Screen Unit
1 Self Adhesive mounting stand
1 AC wall adapter
Cable Kit
Instruction Manual
Software CD for touch screen
External Specifications:
Video Source Input VGA analog male connector (15-Pin D-SUB) x 1 RCA composite video female connector x 2
Audio Source Input RCA audio female connector x 1 (Internal Speaker)
Touch Panel Output RS-232 female connector x 1 Power
Source Input Single 12V DC IN (Supports 11V ~ 24V)
External Buttons Input TACT OSD buttons for Menu/Select/Increase/Decrease TACT PWR button for power switch
Internal Specifications:
LCD Module : 7 Panasonic TFT LCD module (EDTCB18QCF)
LCD Native resolution : 800 x 480
Supported display resolution : 640 x 480 ~ 1600x1200
Supported refresh rates : 60, 72, 75 Hertz
Brightness: 200 cd/mē
Touchscreen : EELY 4 Wire Resistive touch panel.
Video Format : NTSC/PAL
Auto-detect Hot Keys : Available while in off
Power Supply: DC 11V - 24V, 1A
Power Consumption: <8W
Auto Power On/Off with signal
Menu Colors : 18-bit (262,144 Colors)
OSD Menu : Digital Style
Operating Temperature: 25°F - 155°F
Dimension : 7.75in. x 4.75in. x 1.4in.
Weight : 1.3 lb
I would post pictures but don't know how. I can email them if you wish.
I'll take $279 shipped in the United States.
