How much for the USB to IDE device?
I'll give you 20$
These the stuff I got for sale
Vga to ntsc or pal or s-video controoler , comes with all wires to hook it .
Usb to Ide/Atapi device comes with software, power supply , brand new
56 kbps interal pci data/fax windows modem ,brand new
Profile SP62 6.5" 2-way 120 watts max
Pyranmid Gold Series Amplifier 200 Watts x 2ch class a bridgeable amplifier
If you look for somthing not post it post it here or email me and see if I can hook with what you need !
www.sounddomain.com/id/2000mp3ranger
Mp3 player - 10.4 Allbrite Gigabyte GA-71XEH , 700 mgz t-bird , coolmaster fan , 2x 128 ram + 1 512ram , ATI-RAEON RV100 ,on bd sound , Linksys Wireless-B usb network adapter , 20G IBM TRAVELSTAR
I'll give you 20$
Clarion 200watt head unit w/ Aux in.
Kicker 800watt 4 channel amp
In a 96 Grand Prix SE.
give me $30 us dollars and we got a deal.![]()
I'm sorry, I can't, I really don't even have 20$ right now. I'll probably just get one at Best buy when I need it.
post a pic so i can see what the usb to atapi looks like I might want it!
Have you used it, and if so how well is it recognized in window or mac?
Yes I have used it I had no touble loading the software on my home computer running win98 . I hooked up a ide dvd player to the USB to IDE device.![]()
did you just leave the dvd drive out in the open connected to the converter? Do you think that it could work with a cd-rw?
FEATURES:
· USB to IDE/EIDE/ATAPI
· Use With HDD, CDROM, CD-RW, DVD
· Meets USB 1.1 Specification
· Windows® 98, ME or 2000 Compatible
· Apple® OS 8.6 or OS 9.0 Compatible
· Connect/Disconnect Without Reboot
· 6.5 foot Cable Length
DESCRIPTION:
The Model UD-100 adapts IDE, EIDE or ATAPI devices to USB. The electronics is built into the connector housing, which contains a standard 40-pin "hard drive" connector. The converter itself is powered from the USB connection. A power supply, with a standard 4-pin disk drive power connector, is also included. Software drivers for Windows 98, 98SE, ME and 2000 are supplied. Drivers for Macintosh OS 8.6 or higher are also included.
TYPICAL APPLICATIONS:
You can add most any type of portable storage to your PC or Mac using the UD-100. It is compatible with IDE, EIDE and ATAPI devices, including Hard Disk Drives, CDROM drives, CD-RW drives, DVD-ROM drives and LS-120 drives. A CDROM, included, contains all necessary software drivers.
SPECIFICATIONS:
Operating Voltage: 5VDC derived from the USB Connector
Operating Temperature: 0°C to 50°C
Storage Temperature: -20°C to 50°C
67mmX 45mm X 11mm
Cable Length: 6.5ft. (55cm.)
Compliance: FCC Class B, CE
web page
