Results 1 to 8 of 8
Thread: FS/FT EPIA-E533 ( Japan's version of the EPIA-5000 ) Mini-Itx fanless motherboard
    Jul 2005
    Traded
    EPIA-E533 (Japan's model but same as EPIA-5000 ) $ TRADED (My WTTF is at the bottom of this thread.)
    this thing is tiny, and quiet. It comes with the original box, cd, manual, I/O plate and one IDE cable. Great for a tiny HTPC / Car MP3 player.
    Here are the specs:
    Form Factor - Mini-ITX
    - 170mm x 170mm
    - Micro ATX Chassis Compliant
    Processor
    - VIA Eden 533Mhz EBGA Processor
    - 100/133MHz Front Side Bus
    - low power consumption
    - Fanless
    Chipset - VIA Apollo PLE133
    - VT8601A North Bridge
    - Featuring integrated AGP 4X graphics
    - VIA VT8231 South Bridge
    TV-Out
    - High quality scaling and filtering
    - S-Video or Composite video output
    - Supports NTSC/PAL TV formats
    Main Memory - Two 168-pin DIMM memory sockets
    - PC100/133 SDRAM support
    LAN - VIA 10/100 Ethernet LAN onboard
    Graphics - Integrated AGP4X with 2D/3D Graphics Acceleration
    - Motion Compensation for DVD playback
    Audio - VIA VT1612A AC'97 onboard
    - 3 Audio Jacks - Line-Out, Line-In and Microphone-In
    - Sound Blaster, Sound Blaster Pro Compatible
    - Digital I/O compatible with consumer mode S/PDIF
    Expansion Slots - 1 PCI slot
    Onboard IDE - ATA/100/66
    I/O Ports
    - 3 Audio Jacks - Line-out, Mic-in and Line-in
    - Four USB ports (two USB ports located at rear side and two via internal mini USB header)
    - 1 EPP/ECP parallel port
    - 1 16C550 compatible serial port
    - 2 External PS/2 Compatible Keyboard /Mouse ports
    - 2 TV output ports (S-Video or optional RCA TV out)
    - 1 RJ-45 LAN port
    - 1 PCI slot (Note: support for two PCI devices)
    Power Supply -ATX Power Supply Compliant
    WTTF:
    Looking for a decent laptop HDD with 5400rpm at least
    Low end 939 CPU
    My heatware: swiftwind
    Thank you for your time as always!
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    check out my forsale you liek something from there and want to trade
    Jul 2005
    Unfortunately no, however, If you come up with the money or a laptop 5400rpm hdd or even new items for trade, be sure to contact me asap.
    Thank you for your offer though!
    FLAC ukchris's Avatar
    Nov 2003
    Massachusetts
    I could probably get you a drive, how big do you need? Will need to confirm speed though. Interested?
    I this board faster than the M10000?
    Jul 2005
    I'm looking for something between 40-80gb, must be 5400rpm, cache size can vary. Also, depending on what size drive you can get, we will work on something out. I don't believe it is faster than the M1000. Please be sure to PM me if you get a hard drive for sure.
    Thank you.
    Nov 2003
    Massachusetts
    I have a 40Gb Toshiba drive sitting on my desk right now, a couple actually, but there is no speed specified on the label. PN is HDD2171 or MK4019GAX
    Just deliberating as I just got an M10000 and don't really need another board, but I don't really need the drive either so a swap is always interesting.
    Nov 2003
    Massachusetts
    Says here is is 5400rpm, 16mb cache http://www.cmishop.com/store/ShowDet...xtSiteTrack=FG
    Jul 2005
    ygpm
  1. Replies: 3
    Last Post: 05-06-2005, 10:29 PM
  2. FS/FT: 2x Via Epia M10000 1GHz ITX
    By Nico3k in forum Classified Archive
    Last Post: 03-14-2005, 10:27 AM
  3. Bargain!! Via Epia Nehemiah 1ghz Mini Itx Mainboard
    By dave0109 in forum Classified Archive
    Last Post: 05-26-2004, 06:40 AM
  4. FS/FT: Via EPIA 800 Mini-ITX motherboard including 128mb PC100!
    By Ashlawn Kemling in forum Classified Archive
    Last Post: 12-19-2003, 01:54 AM
