Results 1 to 10 of 12
Thread: FS/FT: Fujitsu Point 1600
    Jul 2000
    Hampton, GA , USA
    I've got a fully working Fujitsu Tablet PC that I need to let go of. Its a 10.4" touchscreen, DSTN, 96 MB RAM, Good Battery, Radio Shack Power Adapter (not an exact match but will charge battery and run the PC), 10GB HD. I have all the drivers for it.
    http://www.attentiontodesign.com/forsale/point.jpg
    Please ignore the "NO HD" on the case, this comes with a 10GB HD.
    $75
    Or I will trade for an advantech SBC with around 200 MHz +, like a PCM 5820.
    Steve
    steve@attentiontodesign.com
    System Status - Starting Over
    Computer: None
    Vehicle: Silver 2002 Malibu
    FLAC migel628's Avatar
    Mar 2004
    New Windsor, NY
    What's the CPU type & speed?
    "I'm a dick!"
    "I must seek knowledge and it's bastard son truth" - The State
    Jul 2000
    Hampton, GA , USA
    Intel P166MMX
    Computer: None
    Mar 2004
    New Windsor, NY
    Any pics of it in action?
    "I'm a dick!"
    Jul 2000
    Hampton, GA , USA
    I had some pics of it working somewhere. Let me see if I can find my digital and snag a few pics for you.
    Computer: None
    Mar 2004
    New Windsor, NY
    Also, what kind of ports does it have (USB, Serial,...)? Does it have a PCMCIA slot?
    "I'm a dick!"
    Jul 2000
    Hampton, GA , USA
    I cant find my camera to take a picture of it. However I do promise you it works excellent.
    Here are all the specs:
    Technical Specifications
    CPU: PentiumŪ MMXTM 166 MHz
    Memory: 32 MB SDRAM on-board - 96MB Installed
    Expandable using 144-pin DIMMs
    HDD: 2.5" Ultra DMA/33, shock mounted
    LCD Resolution: 800x600
    LCD Size: 10.4 in / 264 mm diagonal
    LCD Technology: Passive (DSTN) Color
    Digitizer: Resistive tablet, 100 points per second sampling rate
    Audio: Sound Blaster Pro Compatible, full duplex
    PCMCIA Compatibility Revision 3.0 (only the user-accessible slot is CardBus compatible)
    Built-In I/O: PCMCIA: 1 Type III (user-accessable)
    1 Type II (embedded)
    RS-232: DB-9
    USB: 1 Series A receptacle
    Kbd/Mouse: PS/2 6-pin DIN
    Microphone: 3 mm jack
    Headphone: 3 mm jack
    Infrared: IrDA 1.1
    FDD: Fujitsu Proprietary
    Size: 11.7" x 8.7" x 1.4" / 296 mm x 222 mm x 36 mm
    Weight: 4 lb. / 1.8 Kg (with battery pack)
    Computer: None
    Mar 2004
    New Windsor, NY
    $50 shipped? Let me know...
    "I'm a dick!"
    Mar 2004
    does this respond only to stylus or does it respond to finger touch as well?
    Thank You /////ALPINE
    7" Lilli. GPSlim236. Streetdeck. Mappoint. M9000. M2ATX, XMDirect
    Jul 2000
    Hampton, GA , USA
    Finger touch works just fine. I dont have a true "stylus" for it. So I have been using my finger with great results.
    Computer: None
  1. Help With pinout for F-Bus Fujitsu Ten
    By Mach102 in forum Input Devices
    Last Post: 06-19-2005, 07:53 PM
  2. OPUS point of load
    By lostreception in forum Power Supplies
    Last Post: 06-15-2005, 11:46 AM
  3. FS: Fujitsu subnotebook (B2131) small laptop with touchscreen
    By NordicNINE in forum Classified Archive
    Last Post: 09-25-2004, 11:34 PM
  4. Replies: 4
    Last Post: 02-26-2004, 10:52 AM
  5. Fujitsu Touchscreen Laptop for sale!
    By DStylez847 in forum Classified Archive
    Last Post: 11-07-2001, 03:13 PM
