Results 1 to 3 of 3
Thread: Phoenix Gold 4 channel amp
    Oct 2004
    I need a 5 channel amp (willing to consider trades)... i bought this thinking that my center channel would be sufficient self-powered (running a 5.1 system)... and unfortunately thats not the case.... i need another amp to power the center... i already have 2 amps in the car and don't want to add another one... so i'm hunting down a good 5 channel amp.
    Used for under 2 weeks.
    175 shipped
    Freq response +/- 1db 20hz - 20 khz
    Signal to noise ratio >110db
    12db continuously variable crossover
    Crossover range 40hz-400hz
    Bass boost "Twin T bass EQ"
    Input sensitivity 200mv
    Impedance 2-4 ohm
    50 x 4 Watt cont RMS @ 4 ohm
    75 x 4 Watts cont. RMS @ 2 ohm
    150 x 2 Watts cont RMS @ 4 ohm
    80 x 4 Watts max RMS @ 2 ohm
    125 x 4 Watts max RMS @ 2 ohm
    250 x 2 Watts max RMS @ 4 ohm
    8 guage inputs power and ground
    Grained Aluminum finish
    Carbon fiber badge with blue LED backlighting
    Full range thru outputs
    Remote monitoring port
    Dimensions 13.75"L x 10.875"W x 2.25"H
    Jun 2005
    phx amp
    what series is it?
    Mike
    Variable Bitrate nitropwd's Avatar
    Sep 2003
    bloomington,mn / moss point,ms
    any pics?
    Motherboard: Epox MATX
    Power: M2-ATX
    Storage: 120gb 3.5"
    Optical: Slim Slot cdrw/dvd
    Audio: SB Audigy 2
    GPS: BU-353 & iGuidance 4
    OS: Win FLP (Fundamentals)
    Frontend: Roadrunner (DFX 3 & 4)
  1. Replies: 26
    Last Post: 12-20-2005, 07:23 PM
  2. FS: Kenwood KAC 744 4 Channel Amp $90 shipped
    By jeeplaw in forum Classified Archive
    Last Post: 06-20-2005, 10:51 PM
  3. Bazooka 4 channel Amp
    By tiggs in forum Classified Archive
    Last Post: 06-03-2005, 11:52 PM
  4. Replies: 14
    Last Post: 05-11-2005, 09:03 PM
  5. FS: Phoenix Gold TI600.2 amp, new, never used
    By dyeinbreed in forum Classified Archive
    Last Post: 05-02-2005, 01:13 PM
