Results 1 to 6 of 6
Thread: FS:CD player, amp, and speaker combo
    Newbie deskcom's Avatar
    Unit is in Like new condition. Used for less than 2 months total.
    All equipment is garanteed
    Asking $250.00+shipping from zip code 65583.
    Payment is preferred through paypal.
    CD Player:
    Pioneer DEH-P4600MP
    CD/MP3/WMA receiver with CD changer controls
    Details:
    » detachable, fold-down face
    » blue and white display
    » plays CDs, CD-Rs, and CD-RWs (including discs loaded with MP3 and WMA files)
    » displays MP3 and WMA titles (up to 16 characters)
    » Supertuner IIID
    » 18 FM/6 AM presets
    » Easy EQ — five preset EQ curves with 3-band parametric adjustment
    » Front Image Enhancer — removes high and midrange frequencies from rear speakers
    » loudness
    » source level adjustment
    » MOSFET50 internal amp
    » XM radio-ready (XM Radio subscription, tuner, antenna required to receive the satellite radio signal) — service is available only in the lower 48 states, not available in Alaska, Hawaii, or U.S. territories
    » CD changer controls
    » front and rear preamp outputs
    » optional auxiliary input
    » wireless remote
    » clock
    » 22 watts RMS/50 peak x 4 channels
    » CD frequency response 5-20,000 Hz
    » CD signal-to-noise ratio 94 dB
    » FM sensitivity 8 dBf
    » warranty: 1 year
    Amplifier:
    Sony XM-2200GTX 1200 watt
    * Amplifier Type: 2-channel
    * RMS Power @ 4 Ohms: 200W x 2
    * THD at 4-Ohm RMS Power: 0.01%
    * Bridged RMS Power @ 4 Ohms: 500W x 1
    * Speaker Level Inputs: Yes
    * Preamp Outputs: Yes
    * Built-In Crossovers: LP
    * Bass Boost: 0 - 10 dB
    * Frequency Response: 5-50,000 Hz
    * Signal to Noise Ratio: 100 dB
    * Fuse Rating: 2 x 40 amps
    Subwoofer:
    Power Acoustik FUBR-12
    # Non-Pressed Paper Cone
    # Die-Cast Aluminum Basket
    # Diamond-Cut, Wrinkle Finish Back Plate
    # Dual Conex Spiders with Woven Leads
    # 2" ASV Voice Coil
    # One-Piece EVA Rubber Mounting Gasket
    # Chrome Binding Posts
    # Oversized Foam Rubber Surround
    # Mounting Depth: 6.75"
    # Mounting Diameter: 11.125"
    # Size: 12 inch
    # Rec. Sealed Box Dims: 1.00 cu.ft.
    # Rec. Ported Box Dims: 2.20 cu.ft.
    # Free Air Usage: not recommended
    # Sensitivity: 91 dB
    # Frequency Response: n/a
    # Recommended RMS Power: 700W
    # Peak Power Handling: 1800W
    # Impedance: dual 2 ohms
    Carputer Status:
    {▓__________} 10%
    Its not original, its just something no one has failed yet!
    Apr 2005
    How much for just the cd player?
    i have a cd changer input to rca(aux) adapter for that cd player do you want that with it.
    Carputer Status:
    {▓__________} 10%
    The Lavender Tie Just
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    Quote Originally Posted by deskcom
    Is that the CD-RB10?
    Apr 2005
    No Just the cd player
    Quote Originally Posted by Rafster
    yes it is
    Carputer Status:
    {▓__________} 10%
  1. Powering Carputer and amp ...
    By TxMazda3 in forum Newbie
    Last Post: 06-03-2005, 04:12 AM
  2. Help hooking up subs and amp? Need advice...
    By jedi7001 in forum Car Audio
    Last Post: 05-17-2005, 02:28 AM
  3. car amp with default speakers?
    By 273BeLow in forum Car Audio
    Last Post: 03-30-2005, 12:53 AM
  4. Replies: 11
    Last Post: 09-02-2004, 04:11 PM
  5. Replies: 3
    Last Post: 05-10-2004, 03:58 PM
