Results 1 to 5 of 5
Thread: FS: 12 Volt Ignition Backup Batteries
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    Post FS: 12 Volt Ignition Backup Batteries
    I have two Ni-Cad batteries that I was going to use for surviving cranks but I didn't need to.
    They are 5.1ah 12volt Ni-Cd.
    $9 shipped each $16 for both anywhere in the US via USPS Priority with Tracking.
    I accept PayPal only
    PM me if you are interested.
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
    Mar 2005
    Huntsville, AL
    how would you recharge these? with a standard battery charger for a car?
    Jan 2002
    Long Island, NY
    You can hook it up somehow in the car to charge, but I used my RC Plane charger to charge them.
    You will need some special charging circuit to charge them in the car if you want them to be recharged each time the car is on.
    Here is the link to the original seller of the batts:
    FS on Ebay 12VDC 5.1Ah Ignition Backup Battery
    Here is a post on wiring a similiar setup:
    Battery based tank circuit (tested)
    Maximum Bitrate seanz0rz's Avatar
    Jun 2005
    Cal Poly Pomona or Redlands, CA
    i am interested. let me find a charger for em and ill let you know.
    Jun 2005
    i cannot find an economical solution for a charger. sorry. was not intended for my car, so maybe someone else had a use for em.
  1. Regulated 12 volt to 5 volt conversion - Howto?
    By psyclobe in forum Power Supplies
    Last Post: 04-21-2010, 05:24 PM
  2. FS on Ebay 12VDC 5.1Ah Ignition Backup Battery
    By TheSpecialist in forum Classified Archive
    Last Post: 03-24-2005, 08:32 PM
  3. FS: computer controlled 12 volt 6 channel equilizer
    By WhiteRabbit in forum Classified Archive
    Last Post: 03-23-2005, 01:40 AM
  4. 12 volt DC-DC Converter
    By 4u2n in forum Power Supplies
    Last Post: 11-15-2004, 03:13 AM
  5. Replies: 0
    Last Post: 01-12-2002, 04:38 PM
